Results 1 to 16 of 16
Thread: Best fuel for my VL
    VR CALAIS
    Mar 2010
    Wink Best fuel for my VL
    Hey guys,
    I wana know what is the best fuel for my VL. I just changed fuel filter and put in platinum plugs. I was gona give that Vortex a go but is it worth it?
    VT spac super6
    Nov 2008
    Riverton sa
    Simple answer, i dont think paying 10-15cents per L is really worth it in a n/a vl
    i tried everything i could buy locally, 91, 94 bio, 95 and 98,, the difference i found, even with the timing well advanced was very small and not worth the extra money
    96 VS Acclaim Wagon w/VX clubby body kit
    Jan 2010
    Belmont, Perth, WA
    ^^^ agreed
    i've done the same thing in the past in WA, and even tried it with slightly modified cars and still not really worth the extra ya paying
    vy2 clubsport
    Feb 2008
    adelaide
    VR CALAIS
    Mar 2010
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    VL Berlina turbo, VL SL turbo ~STOLEN~
    Aug 2007
    Newcasstle
    Jezza's Avatar
    Jezza is offline Ecotec Just Kicked In!
    VYII Acclaim
    Apr 2009
    South Australia
    i put 98 when i first got my car only because it wasnt driven in over a year so i did it to clean out the car but after a while i went to normal 91 and no real difference in performance and economy
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    b4 my convert i used 91 all the time started fine drove fine.. etc etc
    when i put premo 98 it started likea dog and ran like a dog. so back to 91 it was...
    now with turbo premo 98 and all is well...
    VR CALAIS
    Mar 2010
    Will running Caltex thru it cause engine pinging? Does it cause any damage?
    Thanx
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    not at all man i run Caltex Vortex caus i have a fuel card from work for caltex Servos and no probs with pinging,,,, running a cooler as well... 15 degrees timing as well on 6psi
    vl berlina wagon 6cyl
    Jul 2005
    does the VL get a buildup of carbon in the combustion chambers, raising the compression ratio so needing a higher octane
    VS Executive
    Nov 2008
    Wollongong
    Can you move the dizzy and adavnce the timing?? If you advance the timing until it starts to ping and then put premium in you may see some improvement in power/fuel economy....
  15. #15
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
  16. #16
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    any just make sure ur cars upto service and dont drive with a heavy foot all the time, naturally the highway is better, less stop and go all the time like in the city.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
  1. blockage in fuel line - appears to be fuel pressure regulator??
    By ryan1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2011, 06:23 PM
  2. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  3. fuel surge turning right? weird inst fuel readings
    By vkotis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2006, 12:00 PM
  4. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
  5. fuel injected 5ltr motor setup for dual fuel
    By ma77es in forum Swap / Wanted to Buy / Trade
    Last Post: 28-05-2006, 07:03 PM
