Results 1 to 4 of 4
Thread: Chasis number stamped in body????
    vlrad Guest
    Default Chasis number stamped in body????
    Hi I have two VLs - I want to put all the good parts onto one. I want to keep the original motor and chasis numbers matching.
    So is there any stamped VIN number on the chasis?????????? I can transfer the alumium plates to go? For example the old EH 350CheV I had 5 years ago - there was a stamped number in the chasis which would be a real bumper going to the nats and being pulled over. The alum plates use to come off - I even had plastic push-ins so that I didn't have to rivet the tag on.
    Nothing sus about this question I own both cars - I am just sick of the rust in one with the good mechanicals and sick of the bad mechanicals in the one with the better body.
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    That is against the law, im pretty sure in every state and youll be screwed bigtime getting caught doing this.
    what state are you in?
    Is the car with the bad mechanicals registered? If it is all you need to do is put the good gear in it then head down to your rta (vicroads etc) and have them change the numbers on their system. when you write off a car its the body numbers that are written off, so teh engine etc can be used in another car. the body cant be.
    so if your good body is not registered youll have to get the car roadworthy and registered. explain the engine is from another car which you can prove ownership of (as i assume the other car is still registered in your name) you can put the same plates on the good bodied car but it would require a transfer of rego and a few fees and documents here and there.
    all in all you cant do what you would liek to do. if you swap the motor over you cant swap the chassis number because its A DIFFERENT CHASSIS!!!
    youll just have to swap it over and get the other car registered. done properly your number will match up in the rta system and youll never have a problem.
    vlrad Guest
    Yes - I think the key is that tags can't go on a newer body. Tags belong to the chasis. The trick is like you say - Engines can be changed and rta notified.
    Thanks for your feedback
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    cheers goodluck with that mate
  1. F.S Vk HDT stamped group a grille
    By SthEastCustoms in forum Parts And Other Items For Sale
    Last Post: 26-09-2007, 08:47 PM
  2. VN/VP with Patrol Chasis
    By manvr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-11-2006, 05:24 PM
  3. Throttle body to intake plenum seal part number
    By deeranp in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2006, 05:25 PM
  4. how many places on VX body can I find the VIN number
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-03-2006, 02:29 PM
  5. Is the VIN or chassis number stamped on the actual chassis ?
    Last Post: 15-12-2005, 08:49 PM
