Results 1 to 3 of 3
Thread: VL Stalling on warm idle
    VL Commodore
    Mar 2010
    Default VL Stalling on warm idle
    Hi,
    I have a VL 5 Speed Manual 6cyl running only on petrol. The last 4 months I have been having a problem when the engine is warm it will either idle very rough or stall at the lights or stopped in traffic. If I manage to keep it idling when I take off and change from 1st to 2nd it also looses all power (does not stall if I pump the accelerator). I have taken it to a mechanic and it's had it's head, radiator, leads, plugs and crank angle sensor replaced and the MAF meter and fuel pump have been checked out, there also seems to be a fair bit of black smoke coming out of the exhaust latley at idle, it leaves black carbon like stuff on anything that is parked behind the car, not sure if this is related. When the engine is cold it runs just fine. My mechanic is running our of ideas and would love to hear any fresh ideas from everyone here. Thank you in advance.
    Kirsty.
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    Check your ECT sensor ( engine coolant temp ) fine when cold but once warm the sensor reading is still cold even after running for 30 minutes ECM thinks engine is still cold and runs in rich mode , common problem for VL 6cyl
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    thats what i rekon as well ECT sensor
    as well could be O2 Sensor.
  1. Horrible idle when warm
    By justice4all3000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2010, 01:09 PM
  2. Hard to start when warm and stalling
    By 89berlina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-01-2009, 10:07 PM
  3. Missing at idle (when warm?)
    By M-Leach in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-07-2008, 10:13 PM
  4. VP Calais Stalling during warm-up.
    By Kramerscousin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-07-2006, 08:20 PM
  5. Rough idle when warm
    By Motorsport in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-11-2005, 01:55 AM
