Results 1 to 11 of 11
Thread: Re-conditioned AFM?
    VL vacationer 3.0l
    May 2009
    Christchurch, NZ
    Default Re-conditioned AFM?
    I have replaced my AFM with second hand ones twice in the last few weeks, now I'm starting to wonder if it's possible to re-condition them?
    and,
    The last one I took off, the car was running super black, barely running, and I put on another AFM, the car ran OK again.
    The AFM I removed was near 650ohm across pins 1-6, and 1.6V across pins 2-3, back-probed with the ignition on. So it looks OK, but the engine would hardly run.
    any ideas?
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    its Fu*#ed
    reconditioned would roughly cost same as a second hand one man so just go wreckers and get another.. keep reciept just incase it is already stuffed from accident and check the hot wire inside is not broken.
    VL vacationer 3.0l
    May 2009
    Christchurch, NZ
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    Quote Originally Posted by BigOne View Post
    thanks nath
    if the hot wires look in good condition pull the lid off and hit all the solder joints with a soldering iron and try it they are bad for dry solder quite often makes them like new worth a go if its just sitting there ready to throw out
    vl berlina wagon 6cyl
    Jul 2005
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    calais24/7's Avatar
    Jul 2009
    calais24/7's Avatar
    Jul 2009
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    calais24/7's Avatar
    Jul 2009
    Well whatever :P They are less temping to f*** around with hows that sound
