Originally Posted by
http://farmhub.com.au/print.aspx?alias=carpointau&tabID=6485&ArticleID=6 695&ModID=16538
BUYERS CHECKLIST
* The VL was always a high theft risk and a good one is now even higher as expensive parts fail. Don't expect to hang onto it without a customised security system but even that won't protect it from removal on a flat-bed truck.
ENGINE
* The VL Commodore's sleek styling and low bonnet dictated compromises not found under the taller Skyline engine bay. Unless you follow strict bleeding procedures using the special engine bleed screws when flushing or refilling the cooling system, a full radiator in a VL Commodore is no indication that the engine will contain the necessary coolant. Air locks can stop the radiator's contents from circulating and cook the engine.
* The Nissan engine's inlet manifold and water jacket had to be lowered to fit under the Commodore bonnet. In the event of leaks or air locks, this causes the Commodore's head to drain into the inlet manifold leaving the empty head to cook and crack. Broken manifold studs and cracked heads are more likely as cooling system leaks increase with age.
* The Nissan engine's main radiator hose positions were not compatible with the Commodore's cross-flow radiator when it placed radiator entry and exit points on the same side. An internal radiator baffle was used to force the coolant across the Commodore radiator core but if this baffle dislodges with age, hot coolant can enter and leave the radiator without being cooled. This can also crack the head and do so repeatedly until the cause is isolated.
* The alloy head is sensitive to poor quality and dirty coolant. Unless routinely flushed and filled with fresh, high quality coolant, expect water pump and cylinder head problems. The hydraulic valve lifters are also sensitive to poor quality or dirty oil. The 10,000km oil change intervals under city usage are too long and sludge build-up will generate rattly lifters that require expensive replacement. The cam belt must be replaced every 100,000km. As Nissan didn't expect the engine to require a rebuild, some internal parts can be expensive and difficult to source.
MECHANICAL
* Electric fuel pumps as fitted to the VL depend on plenty of fuel in the tank to keep them cool and free of dirt. Owners who run on empty or run out of fuel will quickly destroy them with many already noisy and on the way out.
* The fuel injection system's expensive air-mass meter is now failing, causing rough idle and plenty of black exhaust smoke. A failed O2 sensor can also cause excessive fuel consumption. Cold start injection components and distributor electronics are now common failure points.
* The VL auto is long lived but lack of servicing will cause failure, starting usually with a slipping overdrive clutch that breaks up and destroys the rest of the transmission. A rumble that shows up at 60-80km/h during a slight incline or any other hint of auto malfunction requires immediate attention before it turns into a $2500 repair. Non-genuine auto parts can save costs but are not always successful so check on warranty terms if the auto has been overhauled.
* In manual VLs, the spigot bush can seize with age and will cause the gears to graunch and wear even with your foot on the clutch. The gearbox has to be removed to fix it.
* The live rear axle depended on voided rubber bushes inside the locating arms to allow the suspension to move up and down but they can soon tear under the VL's power. Some aftermarket bushes that resist the grunt will also lock up the rear suspension and cause the wheels to leave the ground for lethal handling in the wet. Stiff rear dampers can also generate bump steer in the light rear end. Worn Panhard rod bushes are also common and generate unpredictable rear steering. A worn centre tail shaft bearing and broken suspension bushes can generate vibration under power.
* Each Commodore has certain front suspension and steering parts specific to engine and model. Some aftermarket items that don't differentiate between these can generate serious handling and steering deterioration. Rattly steering racks, sloppy rack ends and worn front upper strut pads can cause the car to steer on its own.
* Quality tyres are vital with the power and light rear end.
* The VL's rear drum brakes are often filled with brake fluid from failed wheel cylinders caused by neglected fluid changes. Front disc rotors are often undersized and a soggy brake pedal usually means a master cylinder is ready to fail.
EXTERIOR
* Superficially-repaired insurance write-offs and recycled stolen cars are a real trap. Some of the worst VL examples I have inspected are so bent that the bonnet has been kinked up to clear a strut tower that sits 50mm higher than it should. A vehicle security check won't be enough to uncover a stolen car that is wearing the identity of a wreck so look for any inconsistencies in specification and history.
* Holden's old single-stage acrylic paint process may still be holding up in the solid colours but neglected metallics are now dull and porous, and ready for a respray. Watch out for repairers who have used modern two-pack paints generating a huge difference in shine between original and repaired panels. Replaced plastic bumper sections and side strips will not match in colour.
* The VL Commodore's boot section, despite the big plastic bumpers, will collapse with surprisingly little impact and generate rust in the rear section around the boot opening and near the pillars. Unless a tow bar is reinforced up to the rear axle, even moderate towing can distort the rear bodywork. Look for a poorly-fitting bootlid or tailgate ready to generate lethal exhaust leaks and water leaks generating rust under the luggage mat.
* Non-genuine lights and panels are rife. The genuine headlights and tail lights vital to the VL's appearance might be expensive but faded and water-logged replicas are no substitute especially if they fall apart internally and catch fire.
INTERIOR
* The VL Commodore had bonded front and rear screens with poorly prepared metal underneath, a problem worsened by sloppy windscreen replacement. Breaches in the screen bonding can generate serious water leaks and rust which may require the metal supporting the screens to be cut out and replaced at substantial cost. Watch out for missing screen metal that has been bogged up for sale. The really bad ones will have rotted parcel shelves and floors.
* Some cabin plastics and switch gear verged on the shoddy so check all interior fittings. Earlier square backed front seats were replaced by the VN's rounded seat backs late in 1987 as a running change. Odometers almost without exception failed between 70,000km and 110,000km so any assurances about a speedo reading need to be backed up by genuine records.
