Results 1 to 6 of 6
Thread: VL Calais no start when warmed up
    MY 8.5 Calais V 6.0L, 88 VL Calais Turbo
    Jan 2006
    Default VL Calais no start when warmed up
    Before i took my VL off the road for a respray i had no problems, During the respray everything including engine and wiring were removed.
    When everything was installed it started fine but after the last few weeks it wont start at all when its at operating temp (no spark) but once you start it cold it will run until it warms up and then idles rough,If you turn it off and try to restart again warm it wont fire at all.
    Ive replaced AFM (new) CAS including new plug (new) PT (new) coil (new), New EFI relay, Tried another 3TA ECU but nothing makes a difference.
    Im pretty much at the point where everything has been replaced and the fault still exists, Only thing i can think of is the engine loom is stuffed or something. Or possible the CAS but its brand new, Maybe i got a dud.
    Any ideas would be great as im ready to burn the thing.
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    charged the battery? :P
    Quote Originally Posted by BIGbrown1 View Post
    Hey dea, financed my VS 3yrz ago, desper8 4a car, meter read 214,016kms... I PAID $14,000.00, 3yrz l8r im dealin with alot of problemz... n e cheap BUT good mechanix in west melbourne? n e info appreci8d... Fanx...
    Quote Originally Posted by Menace38L View Post
    yea if i end up getting it il lay low from the cops lol jus want it for skids etc lol
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    it really sounds like a cas problem the only other thing I can think of would be the transistor on the side of the distributor.
    I know you have replaced them both but that is what it sounds like.
    uhh! what about an air leak between the afm and the throttle body? as the engine bay heats up causing the intake tube to expand or contract opening up a join allowing air in.
    or as you have suggested a faulty connection in the wiring loom.
    Nobody wants to play with me
    Jan 2006
    Ive put in another CAS and the PT is firing the coil but only after a fair few cranks, I know my battery is shagged as i have to charge it after every attempt at starting it.
    The fault seems to have changed a bit cause it runs rough at idle, If you try to get the rev's up it has a bit of a flat spot and is fine at 2000 rpm then it will idle for a while then the revs will surge up and down like its trying to correct itself.
    I will put a new battery in today and see if it makes a difference.
    Jan 2006
    Replaced the battery and all is good, Who would have though that would cause these sort of problems.
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    check your alternator as well man just for piece of mind..... so you dont drain your new battery/...
    get a multimeter on volts and check the battery posts when car is at idle you should have around 14.2 volts meaning your alternator is fine,.,,, when u switch of your car the volts will drop slightly to around 12volt
    if u have a low reading at idle the alternator is stuffed basically under 14volts your alternator has blown some power diodes and is on its way out...
    goodluck
    and well done all is fixed,,,
  1. VL Calais wont start!
    By wynnz_10 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-02-2010, 09:23 PM
  2. vn calais wont start
    By millaz88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-12-2009, 04:15 PM
  3. VS S2 Calais, won't start! please help!
    By Deutscher in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2008, 11:44 PM
  4. hard to start when its warmed up
    By MontieVHSL/E in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-08-2006, 10:53 AM
  5. vn calais will not start
    By leety in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-08-2005, 03:30 AM
