VLT running issue
Hey guys i have done a standard turbo conversion to a series 2 motor that i bought for the conversion. Its manual aswell
I'm now having a few issues,
When i start it up cold, and give the throttle a quick blimp, it stutters and runs ****, when it warms up its fine.
It is idling at 1300rpm, unplugging or moving the TPS does nothing at all, i thought it would.
Unplugging the AFM brings the car to almost stall then run ****ty.
Unplugging the Coolant temp sensor does nothing
Unplugging the AAC valve makes the car idle down alot.
Its missing and when i try to drive it, it breaks down once i release the clutch and try to take off, stuttering and running bad.
Does anyone have any idea what could be wrong?
I need to drop the idle speed but when i adjust that screw it hardly does anything.
Sleeper Wagon - In the Build
VP Executive series 2
Check out My Ride
Current ModsWidened S/C CAI, 2.5" exhaust, Advance headers, no bellmouth, 17" VY SS, Foamy TuneFuture ModsNew CarWantedMONEY!!!
Both my vlts run like shit on cold startup.... They take awhile to start and run crap for the first minute or so. Both vls have n/a ecu and injectors... what u running? My idle speed in my berlina is also around 1200rpm when warm... always has been its never bothered me.
1988 VL Berlina turbo 5 speed
http://forums.justcommodores.com.au/...ml#post1446411
1987 VL SL turbo 5 speed ~STOLEN~
http://forums.justcommodores.com.au/...ed-manual.html
unplugging afm and car idles basically telling u that the afm is starting to fail...
what screw are u talking about????
the one on the AFM of the one on your Throttlebody?
running appartent turbo injectors and with a nistune ecu.
It idles crap when i unplug the afm, and im talking about the screw on the back of the manifold
Check out My Ride
Me thinks you need a tune with the aftermarket ecu
