Page 1 of 3 123 LastLast
Results 1 to 25 of 64
Thread: how many kws does ur vl have?
    greatone is offline vuss
    vy ss
    Jun 2005
    Default how many kws does ur vl have?
    wanna know how many kws power ppl have for there vl and what mods they have done?
    To4e VL Guest
    Default Scotts VL
    well i havent re-dyno'd it yet. But at drift nationals last year at oran park it made 210rwhp (158 rwkw) with the stock computer and stok injectors, on a 38 degree day, with no fans. since i have added a haltec E6S, and huge injectors. ill let yuo all know how it goes. in the mean time if u want to add me drift_king87@msn.com.......just got it tuned. now makes 286rwhp
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Mines dead stock except for pod filter and 1 AFM mesh removed, on a good night I'd say 90kw atw (guess)
    Pacemakers are waiting to be picked up and fitted hehe should be good for another 10 or so kw
    ========My Statesman 20's Mafless and 3.9's========
    simbad Guest
    mine is stock and it will leave my dads 2004 ford AU and they have i think 168kw
    VS executive
    Jan 2005
    im assuming its a turbo then?
    Half a carton and still going!!! Now thats Economy
    vlrad Guest
    vlrad Guest
    With a real time test I would say my VL pumps out 70rwponies - both my VLs have 300, 000km which is about right for 18 years - I figure that the odometer misses a little as they don't tend to have more than this.
    DenchY is offline project status = ongoing
    86' VL 323ci
    Mar 2005
    Newcastle
    the old vl t I use to have had over 1 mil on the clock.. still went hard too
    my vl v8 berlina has 250 000 something but its broken so god only knows!!!
    where can i get a new one? besides holden!
    VL Soldier's Avatar
    VL Soldier is offline The rims maketh the ride!
    '87 VL Exec & '95 VS Berlina
    Aug 2005
    Bentleigh East
    I'd say the best place to pick one up is on eBay or a wreckers. They're a prick to fit though (I've heard) you have to pull half the dash apart apparently? Mine stopped at around 200,000 as well. I haven't bothered to fix it though. Wasn't sure where the fault was and I'm not a wizz at that stuff.
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    has the speedo stopped as well or just the odo?
    if its just the odo then you need to pull dash out & put a bit of glue on the white cog so it stops slipping & actually makes contact again. All fixed!
    D.
    Nobody Actually's Avatar
    Nobody Actually is offline luxo barge
    VS s2 Caprice 5l = slow
    Aug 2005
    Queensland
    took it in for a dyno tune, the sheet says 122.6kw at wheels, but as far as i know it's stock. odd for a non-turbo six i thought
    vt exec
    Mar 2004
    well i dont know but would like to know. can anyone give me a guestament on kw.
    its a 6 walker 2 1/2 inch exhaust & extractors
    dont know what has been done to the engine but a mate has a vl with xf throttle bodie extractors and pod filter and cold air intack, and mine will easyily beat his. but any help will be appriciated
    VL to VS
    Mar 2005
    pulling the dash apart is easy once u've done it about 3,000 times lol.
    i reckn i'd know where every screw is... my mate watches in amazement
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    122rwkw is quite amazing if your reading it right considering they came out stock with 114kw at the engine.
    I pumped out 120rwhp or thereabouts when it was n/a- just excuse and filter.
    I got a result when I did the turbo conversion, but it said 130rwhp. And I honestly didn't believe it.
  15. #15
    TAILS83's Avatar
    TAILS83 is offline alcoholics go to meetings
    VPII Club Sport, Build NO# 339.
    Sep 2003
    Brisbane northside
    i dunno i recon i've got about 170rwkw's(estimated). VLT berlina running 13psi, cooler and exhaust. 5 speed man, rest of car is basically stock. i wouldn't try to get any more outta my car till i upgrade the fuel system and turbo.
    Never late, in a 30..4 lol
  16. #16
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    few bits better than stock looking at 150-160. much less when running LPG (which is all i can afford lately.....) nearly 300 000 on the clock.
  17. #17
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    std vl 6 cyl runs 114kw, turbo runs 150kw and V8 runs 132kw. Mine is std with cold air induction, k&n filter, pacemakers, hi-flow cat and sports exhaust and putting stage 2 chip in next week. i estimate my kw's to be more than a std v8 but not as high as a turbo... yet. A bloke at uni-chip also told me all vl's run different kw's. even if the same bloke made it on the same day with the same batch of bits. i do like the idea of removing the mesh, no real point for it. it doesn't filter squat unless you run a pod filter or ram flow that falls apart and sucks into the intake.
  18. #18
    UNR8D Guest
    unless its XR6 or Fairmont Ghia they are 158kw, and even then unless you have a Turbo NO stock VL N/A would hold one off.
  19. #19
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    Is that a stock turbo readout? im certain the V8 pumped more than the turbo from factory....(but i cant back with with perfect numbers so laugh)
  20. #20
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
  21. #21
    VL Crapbox
    May 2005
  22. #22
    VLCT87 Guest
    hey got my calais turbo dynoed stock motor and turbo just cat back stainless 3" exhaust and front mount 122rwkw
  23. #23
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    Exclamation
    Quote Originally Posted by VLCT87
    that seems a bit weak for a turbo with cooler and 3".
    but anyway check out this site for good specifications, VK - VY and on the top right hand side of the page you can select the model and get more info from VB - VZ, its worth the look.
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
  24. #24
    vl & vr commodore
    Oct 2005
    adelaide
    our vl berlina is fairly stock 6 , which we were told had a blown head gasket , that was 12 months ago and still goes strong. Everyday driven car.
  25. #25
    VT SS S2 A4
    Aug 2005
    On my old set up, I made 170rwkw.
    Havent dynoed the new set up yet, but it will be 200rwkw +
