Results 1 to 5 of 5
Thread: electrical fault ideas please
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    Default electrical fault ideas please
    2 weeks ago driving along indicators stopped working, no problem fuse was ok so pulled the flasher unit out had the date march 1988 on it so I got a spare changed them and all was good.
    2 days ago driving indicators stopped working again only now there was no stereo, wipers or cigarette lighter, I parked it and would check it out sunday, go out started the car popped the bonnet checked fuses all good and everything works now, so drove to easter lunch and around a bit then home again all good all day, go out to put the car away for the night and what do ya know
    no indicators, stereo, wipers, lighter and the red BRAKE light (not PARK BRAKE) is on, on the dash.
    any ideas?
    also they all operate on fuses #12, 13, 14, 15 and hazard lights, headlights all work fine.
    Nobody wants to play with me
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    geez no ideas, well I went out this morning to have a look and of course everything works fine now, drove about 50k's then at a mates place thought I'd have a look under the bonnet checking the battery terminals and other wires I grabbed the main black wire to the negative terminal and it was slopping around like a c@ck in a shirt sleave I tightened it up and no problems YET!
    White Tiger's Avatar
    White Tiger is offline Semper Fidelis
    VN Executive Wagon VR Berlina V6
    Jul 2009
    Bordertown SA
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    Quote Originally Posted by White Tiger View Post
    the power of a loose earth is amazing is it not?
    un ffffkn believable, but as always something simple.
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    well the problem has arisen again, it appears to be the ignition barrel or switch, if turned to far or not turned back far enough. so basically it depends on how you start the car.
    now for the fun part of removing the Full Metal Jacket to replace the barrel and switch then refitting the FMJ.
  1. VL Electrical Fault
    By I drive a VL Commodore in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-03-2010, 11:23 AM
  2. vn electrical fault HELP!!!!
    By Zuicider in forum Electrical Wiring / Questions
    Last Post: 25-03-2007, 08:34 PM
  3. Cig lighter electrical fault?
    By JoshsVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-03-2007, 01:47 PM
  4. Thermo fan/sensor/Air con? - electrical fault
    By valet_dave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-04-2006, 12:07 PM
  5. VT ELectrical fault
    By Steve29 in forum Electrical Wiring / Questions
    Last Post: 09-12-2005, 09:57 AM
