Results 1 to 11 of 11
Thread: how to use computer on vl
    vl rb30's Avatar
    vl rb30 is offline vn v6
    vn
    Jul 2005
    Exclamation how to use computer on vl
    how are use i know alot about cars specially old holdens ive had a hr hq lj alot ov old holdens now ive turned to fuel injection a vl commodore just learning about sensors and all of that its my first unleaded vl never turn back can someone tell me how to check and use a computer and how to check 4 problems and what to do and how to operate it very keen to learn thankyou please help
    vlrad Guest
    A Vl workshop manual is a better start than a pre 1070's holden. (having had a 350chev EH, I look forward to working with intel on the VL and have used it to bring my handy work into the 1980s).
    In brief position A on the computer with engine at 2000rpm checks mixture, temperature and oxygen sensor. With the engine off, ignition on, the light sequence tells you about any self diagnostic faults.
    The manual is detailed and it took me 4 weeks from reading it, until I realised that the answers where in the manual.
    Some of the blokes here are great they have all the specs on what output the sensors should read. I used it to diagnose a oxygen sensor.
    If I got in early with the workshop manual and watched I would be about 500 bucks happier
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Arrow
    Quote Originally Posted by vl rb30
    I'll send you some info ok??
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    vl rb30's Avatar
    vn
    Jul 2005
    Quote Originally Posted by vlrad
    no worries mate i just purchased a manuaul today i see what u mean i will have to study it and see how things go ill pick it up thanks 4 your reply helped heaps take it easy
    vl rb30's Avatar
    vn
    Jul 2005
    no worries mate send me some info that would be appreciated thanks heaps take it easy
    vl rb30's Avatar
    vn
    Jul 2005
    hey buddy i know how to use the computer now but how do u now if your got problems the lamps only flash 14 23 24 31 and they sey they should flash so how do i know then when they all flash the error codes
    vlrad Guest
    Yes - this is the part that pissed me off - all the codes came up and appeared in order but I thought - what does it mean.
    I'm using a Max Ellery repair manual.
    I am good for checking that the feedback loop works (o2, temp) - both red and green flash at the same time with engine on 2000rpm and computer screw on postion A (anticlockwise).
    How to get the codes out of the smart computer is something I will work out before I'm done.
    vlrad Guest
    Found this on a thread: -
    G'day Matt
    Yes the manual ECU will still run your car, so it won't hurt trying it out. Those codes are normal.....
    Code 14 is your speed sensor circuit, cancel that out by driving the vehicle at speed greater than 10kph
    23 is your TPS, cancel it by switching the car off then back to the on position and fully depress then release the throttle.
    24 is the neutral switch on your auto, move it down to first then back up to neutral to cancel this
    31 is a system pass for a non airconditioned VL, yours has A/C so it's a a/c circuit, just switch your a/c on then off to cancel.
    After this you 'should' be left with a code 44, which is system pass for an air conditioned VL.
    My only idea is the CAS, as you'll still have spark on a RB30 but not evenly at all cylinders. All depends on how well RACQ diagonosed the prob. Might also be a faulty TPS but that shouldn't prevent it from starting all together. Same goes with fuel, it would have to be literally getting nothing for it not to at least fire then splutter and die.
    Cheers and g'luck
    Jake
    vl rb30's Avatar
    vn
    Jul 2005
    VP EXECUTIVE 3.8 V6 t700
    Jan 2005
    Armadale Perth
    Default Sensors/adjustments
    THE ONE ADJUSTER HIDDEN BEHINND BLACK PLUG ON AIR DUCT NEAR AIR CLEANER GOOD FOR SMOOTHING IDLE AND CLEANER RESPONSE, ONLY A REMEDY WONT FIX CAUSE IE 02 SENSOR, THROTTLE POSITION SENSOR ON THROTTLE BODY, BENT/BROKEN CRANK SENSOR PICK UP. ANY LUCK YOU HAVE AS MY VL STOPPED AND WONT START WOULD MAJORLY APPRECIATED. JIMRICHARDS1964@WESTNET.COM.AU :b:
    VL to VS
    Mar 2005
    Default ecu
    i have a feeling my ecu is up the creek?
    the lights flash very differnt all the time when on diagnostic mode, the green will flash 4 times, then the red twice, then the green 3 times, the red once, and be more n less all over the place... i've noticed the car hasnt been running very well of late, i think that might have something to do with it?
    then again i didnt check to see if i was exactly on 2000rpm as i was checking.
    the max elleries book i dnt quite understand, does ur car have to be in nutreul when on diagnostic mode?
    ...aS thE fOruM JunKie StRikEs aGaiN!...
  1. Resetting your computer and trip computer special functions (VT - VX)
    By Darren in forum Holden Commodore How-To's
    Last Post: 19-01-2011, 07:05 PM
  2. vk efi computer is the computer just for motor
    By quick202 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-04-2007, 11:13 PM
  3. trip computer/total distance computer STOPPED!
    By Juzzy21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2007, 10:10 PM
  4. HELP, need computer wiz
    By immortality in forum The Pub
    Last Post: 03-01-2007, 06:12 PM
  5. computer ram?
    By hispeedvp in forum The Pub
    Last Post: 10-11-2006, 09:26 PM
