Results 1 to 4 of 4
Thread: New to vl
    VL Commodore/ VK Commodore
    Apr 2010
    Default New to vl
    Hey guys, just a slightly different question, im getting a vl 5 speed on saturday, its a suitable turbo motor (oil lines in block), now what i wanna know is, it has extractors and 2.5"exhaust, Cold air intake, new gearbox...now if i wanna turbo or supercharge this car, will i need a whole new exhaust etc things like that im unsure of, another thing is, is there an available kit i can buy with brackets, piping, manifold etc that i can buy and have everything there to do it, without cutting or welding or ****ing around...?? might sound dumb, but im normally a v8 man, not a charger man so i know jack all...
    98 VT Acclaim
    Aug 2008
    New Zealand
    You'll need an RB30 turbo exhaust manifold (you could use most of your existing exhaust system, just get an exhaust shop to make the pipe between the back of the turbo and the rest of the system (dump pipe).
    You could get all standard VL Turbo parts (manifold,crossover pipe,turbo,turbo injectors,turbo ecu), and put it all together.
    Or you could get a Front Mount Intercooler kit like a gkTech one which is pretty much a straight bolt in, no holes kit (http://www.gktech.com.au/front.asp?p...ctID=HVLC-FMIC) would pay to do this if your sticking with the standard (non-turbo) block (higher compression) so you don't get detonation or pre-ignition.
    Look on here in the for sale section for bits - sometimes people are selling the factory turbo manifold/turbo/turbo injectors/turbo ecu/oil and water lines as a package (either coz they're upgrading or are wrecking or whatever).
    That would be the easiest and cheapest way to turbo it, or you could go crazy and spent thousands and have a 10 second car :/
    All depends really on what you want, what sort of power your after, how much you want to spend etc.
    have a look on calaisturbo.com.au - VL NATS TICKETS ON SALE NOW! www.vlturbonationals.com.au - Powered by vBulletin there is a lot of helpful people and info there
    87 exec turbo, vp calais daily
    Apr 2010
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    u can turbs the rb for quite a cheap price with good results, study and good knowledge,,,,
    + we are all here to help....
