Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: VL Wont Start
    VL Commodore
    Apr 2010
    Broken Hill, NSW
    Thumbs down VL Wont Start
    Hey guys
    Wondering if anyone could help, just bought an 86 VL commy, Had it running while i had the hood up and it was running perfect, then the engine just stopped out of nowhere and hasnt started since. Fuel pump works fine, and i have checked all relays and fuses and they are all fine as well. Has spark, It will wind over but just wont fire.
    Plase help Thanks
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    VL Commodore
    Apr 2010
    Broken Hill, NSW
    Yer Mate, has about $15 petrol in it, Air is fine, and has excellent spark, the guy i bought it off yesterday ran it completely outta fuel, and from reading a few other forums it looks like it might be it, took a few hours to get it going yesterday. once it was going it was running perfect until today when it just conked out.
    98 VT Acclaim
    Aug 2008
    New Zealand
    If he ran it dry then its could have sucked up a bit of crap inside the tank meaning the fuel filter could be blocked.
    VL Commodore
    Apr 2010
    Broken Hill, NSW
    soo was just out stuffing around with it me vl an decided to check spark again... NO SPARK pulled leads off an wound the car over an theres no spark at all..... cleaned all connections pulled the cap off cleaned all that an the dizzy...... still no spark so what would be next?? CAS??? ignition coil???? car was running fine yesty then just stopped like someone turned the key off ..
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    charge in battery?
    Quote Originally Posted by BIGbrown1 View Post
    Hey dea, financed my VS 3yrz ago, desper8 4a car, meter read 214,016kms... I PAID $14,000.00, 3yrz l8r im dealin with alot of problemz... n e cheap BUT good mechanix in west melbourne? n e info appreci8d... Fanx...
    Quote Originally Posted by Menace38L View Post
    yea if i end up getting it il lay low from the cops lol jus want it for skids etc lol
    VL Commodore
    Apr 2010
    Broken Hill, NSW
    yeah mate battery is new car just wines an wines over just wont fire cause of no spark at all theres nothing there dead as a door nail....
    Nackerz's Avatar
    Jul 2009
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Try wriggling the wires at the plug that goes into the CAS They have been known to break the wires and will sometimes start if you wriggle them. You can buy new plugs to solder your wires into if this is the problem.
    Nackerz's Avatar
    Jul 2009
    Quote Originally Posted by Tree cutter View Post
    In saying that you can get a CAS with a plug kit to fix this problem
    VL Commodore
    Apr 2010
    Broken Hill, NSW
    so i done as you's have said pull side kick panel off LED working an tried wriggling the plug that plugs on the CAS nothting happened didnt fire up just wound over an over
    Nackerz's Avatar
    Jul 2009
    VL Commodore
    Apr 2010
    Broken Hill, NSW
    yeah fuel pump kicks in an have fuel... ill change the CAS an let ya's no how i went 9 times out 10 it is the CAS goin off everyone on this forum that has had trouble with spark.... this is a good site thanks for all ya suggestions fellers ..
    Nackerz's Avatar
    Jul 2009
  15. #15
    VL Commodore
    Apr 2010
    Broken Hill, NSW
  16. #16
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    sounds like CAS or the plug itself,,,, pull back rubber boot on the CAS plug and check the back of the spade connectors. sometimes corrodes in there and snap off... as well as put some INOX/WD40 in the plug as well
  17. #17
    Nackerz's Avatar
    Jul 2009
  18. #18
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
  19. #19
    VL Commodore
    Apr 2010
    Broken Hill, NSW
    so went an got a price for the CAS $155 ..... thought i'd check on ebay an found them on there with 12months warranty for $78 think i no which one ill be buying car might be off the road a lil longer but dont think that will bother me lol... will let ya's no how the vl goes once it gets here an i've wacked it in..
  20. #20
    Nackerz's Avatar
    Jul 2009
  21. #21
    VL Commodore
    Apr 2010
    Broken Hill, NSW
    thanks for the offer nackerz but i've already bought the one off ebay should be here friday or next monday..
  22. #22
    Nackerz's Avatar
    Jul 2009
  23. #23
    VL Commodore
    Apr 2010
    Broken Hill, NSW
    was out at the wreckers here in broken hill an found a VL Wagon 5 speed manual with 81thou k's on the clock.. i asked about it it belonged to an old guy that died so the wreckers bought it an sat it out the back.. couldn't believe it not many around with km's like that on it..
  24. #24
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    check my sig if u need a how to on changing the CAS....
    hope this is the cause of your probs they are temperemental bloody things, moisture/dirt/ etc does not take much to wreck them as they are LED sensors
  25. #25
    VL Commodore
    Apr 2010
    Broken Hill, NSW
    thx for that detox yeah i no how to change them have already pulled it apart an had a look at it when i pulled the cap off the was a fair bit of crap in it ... she's all cleaned up an covered up waiting for the new one.. hope this is the problem.
  1. wont start!
    By beng in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2009, 08:51 PM
  2. VL wont start
    By vlcalais11 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-02-2009, 09:54 AM
  3. VR wont start
    By Rumbl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-01-2009, 12:35 PM
  4. Help - Car wont start
    By COINERS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2007, 11:01 PM
  5. VR 5L wont start.... PLEASE HELP
    By LMP420 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2006, 10:54 AM
