Results 1 to 9 of 9
Thread: [Question] Wiring up Interior Light Neons To Headlights
    Excale's Avatar
    Excale is offline Aussie N Proud!
    VL Berlina 5sp Manual[SOLD], VN V6[SOLD],VR S 5sp
    Mar 2009
    Melbourne, Aus
    Default [Question] Wiring up Interior Light Neons To Headlights
    Hello,
    Just bought some interior light neons over the internet, waiting for them to arrive soon hopefully. Wondering how would i go wiring it to the head light so when i flick the lights on, underneath the dash where the pedals are will light up.
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    Excale's Avatar
    Mar 2009
    Melbourne, Aus
    Quote Originally Posted by Nackerz View Post
    with the neons, 1 of the wires is earth and the other is power, wire the earth to anywhere and the one for the power of the neons just wire straight into your headlight switch champ
    Ah sweet as man, any ideas how to take the indicator handle off, cause thats where the headlight wire would be aye?
    Nackerz's Avatar
    Jul 2009
    VLC86's Avatar
    VLC86 is offline ..stay N/A..
    VL Calais
    Dec 2009
    Hey i know the thread is getting on. But how would i go about doing the same thing, but attaching a on/off toggle switch so they arn't on all the time? Thanks for any help
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    Quote Originally Posted by *VL-calais* View Post
    easy as mate , one wire power the other ground. jut hook it up to your ciggerate lighter , im pretty sure the borwn is power and black is ground. then simply put a switch on the power wire somewhere
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    in regards to the toggle switch, cut the power wire and simply attach the wire on each end of the switch if that makes sense, it will stop the current going through
    VL Wagon 5 Speed
    Sep 2009
    just solder a wire from the switch you want to your headlight +12 which is under your steering wheel. a multimeter will help you (or a 12v lamp that goes on when current is applied)
    then solder the other switch wire to your neon positive wire, and ground the neon negative. too easy. by doing this the neons will only be on if your headlights are on AND your own switch is on, a handy set up.
    just be careful in how much load you put on your 12v headlight switch, as it's only designed to carry a small load to your headlight relays. might be best to implement your own relay, any questions just ask
    hope this helps m8
    vr commodore
    Aug 2010
    adelaide
    hey mate what neons did you buy could you post a link if theyre any good ??
  1. Cigarette Lighter Wiring - Interior neons
    By HamaTime™ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-02-2010, 03:41 PM
  2. Interior light wiring
    By Philthy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-06-2008, 09:45 PM
  3. VT Fog light switch for interior neons?
    By DARGAN in forum Electrical Wiring / Questions
    Last Post: 09-12-2006, 03:18 AM
  4. Neons to interior light
    By ozzie_online88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2006, 12:57 PM
  5. Interior light wiring???
    By Green machine in forum Electrical Wiring / Questions
    Last Post: 15-10-2005, 11:37 AM
