Results 1 to 4 of 4
Thread: Indicators aren't working!!!!
    vl executive 86
    Mar 2010
    Default Indicators aren't working!!!!
    Hey just wondering if anyone knew about the indicators, have changed the relay, the hazard lights work, the indicators click into place but they do not turn on, havent been able to get the steering wheel off to have a look, any ideas???? thanks
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    do the windscreen wipers work? if not Fuse#14, if so then flasher unit under the dash (drivers side under the steering column behind the ex fusebox cover) if it's not that then indicator stalk, steering wheel off and check the switch mechanism.
    then after all that ignition barrel and/or switch.
    Nobody wants to play with me
    vl executive 86
    Mar 2010
    hey thanks found out that the fuse blows everytime so will have to put in a higher one it recommends 15 amp but am thinking of trying a 20 amp
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    bigger amp the better bro i use 40's and havent had any issues yet.. only one that does blow once in a blue moon is the power cable fuse for the sound system which is 50amp.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
  1. Help! Indicators not working!
    By LittleMissVE in forum Electrical Wiring / Questions
    Last Post: 05-04-2010, 11:57 PM
  2. HELP!! indicators not working
    By 17UCK! in forum Electrical Wiring / Questions
    Last Post: 13-10-2009, 07:25 PM
  3. VR Indicators not working
    By Muik in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-09-2008, 02:24 PM
  4. Indicators Not Working?!
    By 1991_Vn2nV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2007, 06:07 PM
  5. Indicators not working but hazards are?
    By dans_vz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-01-2007, 10:35 PM
