the light in my car wont go off. tried opening all the doors and checking they were pushing the little buttons but i have no idea. thought it might be the fuses. not sure though. as you all know my fuses are highly fried
Half a carton and still going!!! Now thats Economy
I'd be doubting it's a fuse...it's probably more likely the one beside the steering wheel...switch is probably stuffed and not disconnecting the contacts when lever is moved down...this could also apply to the door ones...at one stage my back passenger door didn't switch the light on, i wasn't complaining means i didn't have to get cramped up in the backseat if ya know wat i meanbut it fixed itself.
what do you mean
With the lever beside the steering wheel when it is pushed up to the top it creates a contact which bypasses the swithches in the door, and sends an active and neutral up to the light to make it work, it this lever is stuffed, having it down will still act as if it is up. And same with the door buttons, when the door buttons are pushed out, it creates a contact and sends active and neutral to the light and when they're pushed in it disconnects the contacts leaving the light off, it only takes one of these buttons to not disconnect to leave the light on.
If you pull out fuse 9 it should turn your light off...but this will also kill your clock...if it doesn't turn off your light then your problem is elsewhere. I've never heard of a vl doing this, so wat im saying is only a possibility. Unless of course you just got that lever beside the steering wheel up![]()
lol HAHAHA. i was saying that as a joke at your last crack about the crampage. but thanx for the extra stuff.
pull the globe out. i agree it soundslike it might be the switch next to the steering wheel...
Thought that after i posted...im 6'2 so i can have a sleep with me legs out the door and no light being on after a big night on the pissno crampage.
i figured that. i thought you meant something else though by no crampage![]()
vlacs i think i was on your wavelength....... !
as another thought, it could also be an earth wire has become exposed and is making contact with a chassis earth. interior lights in commodores a negatively switched, put them to earth and they light up! Have a look...
yay! 701 posts w00t!
post pest lol......are newer commies neg switched too?
