Results 1 to 4 of 4
Thread: VL stalling
    VL commodore-1987
    Jul 2009
    Queensland
    Default VL stalling
    There is probably a thread about this but I don't know how to do a search.. Any help would be much appreciated
    My VL... aka Christine, has had unsolved dramas since beginning of the year... 2 cas, and multiple afms have failed to fix the problem.. it has rough idle.. now you have to keep your foot on accelator or it will stall... is at the 2nd mechanic and they have no idea what the problem is... ecu has been checked, all compression is fine.. cas is new, so is afm.... its not drivable, it is rough the whole time.. sorry if its not the best description but i have no idea.. am about to burn it.. will look at every idea thanks guys
    VL commodore-1987
    Jul 2009
    Queensland
    oh & the plugs, leads etc are new... injectors are all good as well... fuel pump working fine, fuel pressure fine.. fuel filter new.... hope that helps a bit
    VL Commodore
    Apr 2010
    Broken Hill, NSW
    could it be a faulty sensor on the throttle body???? i had a vn commy that done the same thing rough idle an carry on .. turned out to be the sensor on the throttle body i forgot what this was called though... have u done a test to see if any faults come up ??? u can test it urself through the plug near ur ecu...
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    TPS (Throttle Position Sensor) Blueylj
    check AAC valve and electrical plug, and clean if necessary as well as there could be an air leak in the air piping between AFM and Throttlebody as well as vacuum leaks(use a Vacuum gauge for a measurement should be around -20psi at idle),
    Air Reg,
    Fuel Reg as well,
    Corrosion on electrics,
    dirty throttlebody and inlet runners from excess Blowby where oil gets into the intake through PCV Valve (Positive Crankcase Ventilation Valve) (from rocker cover to plenum little rightangle hose at front ) to burn off , this causes some problems. Take off throttle body and plenum and give it a clean out. easy job does not take long at all(get it shining take out throttle plate and polish)
    Try cleaning dizzy cup and rotor(Scuff with sandpaper lightly on rotor arm and inspect dizzy contacts inside cup for white powder/pitting and replace if necessary)
    this should clear it..
    thats what i do and it works
    and throttle is more responsive and eliminates take off stutter.
    Goodluck
    Let us know how u went.
  1. Stalling and A/C
    By crae in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-09-2007, 08:01 PM
  2. stalling
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-09-2007, 03:04 PM
  3. VN Stalling
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-09-2006, 01:34 AM
  4. stalling???
    By 84_vk_wgn in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-02-2006, 03:46 PM
  5. Car Stalling
    By Stranger in forum General
    Last Post: 20-02-2006, 12:52 AM
