Results 1 to 4 of 4
Thread: Help with efi conversion
    5Lt VLCalais
    Nov 2009
    Default Help with efi conversion
    hi . i am putting a VQ EFI 304 in my VL Calais. it was factory 5lt so it needs a fuel return line. what is the best way to go about this. should i change tanks and lines . or surge tank and return line. please help with this as i dont know which way to go. is there a better way?
    VC
    Oct 2008
    I have just finished a V6 conversion in a VC and decided it was easier to use a tank out of a VL 6 with the swirl tank built in and with the internal lift pump. I then fitted an external Pierburg EFI pump and filter. All you will need then is a return line, I used rubber EFI hose and ran it along with the other fuel and emission lines.
    86 VLCT/ 03 II VY SS Ute
    Aug 2007
    my mate is nearing the end of this conversion to his vc (had a 253 in it) he used the tank out of the vn and ran what lines he needed.
    '87 VL Calais with L67
    Aug 2007
    you could go to the wreckers and get the fuel return line and tank from a 6cyl. then bend the tabs on the chassis out and fit the return line.
    This is good site to watch.I found it informative as I have been researching a lot lately on such matters such as you talk about.
  1. Vt l67 to vp conversion
    By chargemeup in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-03-2010, 11:21 PM
  2. Man conversion-cruise control, will the auto cruise control work on manual conversion
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2009, 12:25 PM
  3. conversion people conversion
    By flynn84 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2007, 01:25 PM
  4. ABS conversion
    By Kingpin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-02-2006, 01:04 AM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
