Hey all.
Just wanted to let you in on a little knowledge I learnt last night. If one or both of the pop up eyelids on the Calais is left up, whether it is mechanical or just jammed, will drain your battery! I had a small ding to the front of my car a month or so back, it left the eyelid bent out of shape. Once the headlight was replaced the pop-up lights haven't worked.. Anyway, fiddling away with them, one was left slightly up (only about 1cm out of place) Next time I try to start it, flat battery (N) Turns out, when the eyelid is up, it is drawing power from the battery.
Hopefully you wont get in the same situation
