Results 1 to 8 of 8
Thread: Fuel breather hose?
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Default Fuel breather hose?
    Okay ill do my best at explaining, i pulled the fuel tank out of the car cause all of the breather hoses have perished. I just need to know what goes where. There are two on the front side of the tank, one into internal fuel pump and the other fuel return. two on top of tank that go into the charcoal canister and then into the fuel filler tube thing (forget the name) but there is one line that sits in the rear wheel arch and i have no idea where that connects to. any info would be greatly appreciated i need the car running asap
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    calais24/7's Avatar
    Jul 2009
    Thankyou so much mate! thats exacty what i was after. Rep given
    87-88 Calais executive
    May 2010
    Hey I just found this problem yestie, all my hoses hav died with age. I stumbled across this problem while searching for the cause of lots of fuel smells coming from that spot on my car and a damp patch on that little ledge behind the tire. If all these pipes were open like on my car can fuel leak out of them say when I'm turning a corner or going over a bump? If not could anyone explain what are the functions of all the bits in the diagram? Thanks.
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    if the fuel tank is full it is possible to lose a small amount of fuel through the breather hose connections on top of the tank (not the ones in the pic above, on the filler)
    these hoses are part of the evaporative system, the fuel system is pressureised and when driving the fuel sloshes about creating vapour/gases these are then passed through those hoses and into the canister on the right side of the engine near the power steer reservoir at various times the then are put back through the plenum chamber and through the engine rather than into the atmosphere in all it is part of the engine emission control system to help save the planet.
    another possibility for the wet patch is that your fuel filler pipe has cracked where it joins to the tank.
    Nobody wants to play with me
    calais24/7's Avatar
    Jul 2009
    May 2010
    I'm not really sure if there's loss of economy, it's pretty bad tho. Yesturday I did 100kms and went from half to 1/4. And I was only doen 90-100 along the highway. But mmm, I'm
    trying to order in some new hoses so I'll just attach em back up again. Only one problem is there is one hose that comes out from on top of the tank and i can't get to it, but I'll just leave that one.
    If someone could give me a rough idea on how much fuel they use per 100kms? Cause mine just seems too much.
    Thanks, Mick.
    vl berlina wagon 6cyl
    Jul 2005
    this job often has to be done as holden used cheap nasty plastic hoses that rot fairly quickly, also check the fuel cap which should be non vented, its usually plastic and eventually cracks
  1. VN Fuel Tank - Breather hose?!
    By xXBoofXx in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2010, 08:16 PM
  2. Has any body replaced the stock fuel filter clips with new hose and hose clamps? HELP
    By sir_nick2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-01-2010, 08:51 PM
  3. where does the breather hose on my auto go?ive looked everwhere please help
    By trev-355 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-01-2010, 06:11 PM
  4. Where do I run a breather hose from my fuel tank to.
    By bhagl1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-10-2008, 08:30 PM
  5. Breather Hose
    By niggle in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-09-2004, 05:57 PM
