Results 1 to 3 of 3
Thread: VN Diff In VL Commo
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Default VN Diff In VL Commo
    Now i know there is a few threads on this but i wanted to run a fresh thread on this topic, and my application.
    Right i can get my hands on a VN 28 Spline LSD Disk to Disk diff setup free from a mate.
    Now i know this is slightly wider but should not make a difference with my 225's should it?
    is it a straight bolt in...
    Do i need to get another tailshaft?
    I know i need to adjust the handbrake cable
    I know the Ratio is slightly Lower 3.08 apposed to VL 3.45, is it noticeable off the line and so on.
    Also i can get the 1" Master Cylinder from the car as well as i will be losing the drums and having Disk to Disk rear end.
    Vl Turbo ones are getting hard to find.
    Thanks heaps guys
    Nath
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I'm pretty sure you can swap the centres over providing your VL is 28 spline too. The backing plates from the disc setup will bolt onto the VL housing too. Someone else on here did the same conversion. The VL disc rear had the 1" master too so using that is a must.
    Visit my Facebook page
    [TOPGEAR]'s Avatar
    [TOPGEAR] is offline PUNISHER :)
    VS UTE LS1 + VS S3 V8 UTE
    Apr 2004
    Carrum Downs, VIC
    u will definately want rolled guards.
    a mate has one in a vh and it sits very very close with 235/35-18's
  1. $600 Vk commo.
    By vk.jonno in forum VB - VC - VH - VK
    Last Post: 23-11-2009, 08:44 AM
  2. My VX Commo
    By vxhilr8 in forum VT - VX - VU - WH - V2
    Last Post: 02-09-2008, 06:38 PM
  3. Which commo should i get?
    By PEAKN6 in forum General
    Last Post: 07-11-2006, 01:46 PM
  4. 8k commo
    By steino in forum General
    Last Post: 26-07-2005, 09:14 PM
  5. Grr @ my commo
    By tm659 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-09-2004, 10:21 PM
