Results 1 to 3 of 3
Thread: inside the vl calais door
    nick 8x Guest
    Question inside the vl calais door
    hello all,im trying to fit solex locks to my vl calais,got the trim off,got the handles off and speakers out no dramas,but theres a plate with one screw between me and the original key barrel that i need to remove,i took the screw out but the plate won't budge,any help would be greatly apreciated
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    thats the anti-theft plate. You will need to lift the black strip that sits on the outside of the door under the window on the top of the door. I hope that makes sense?
    if you wind the window down & look down the gap from the top you will see (2 or 3 cant remember) little tabs that sit over the door sill under the black bit I mentioned before. Just lift the black bit & then lift the plate up & free of the door.
    D.
    nick 8x Guest
    thanks heaps, that makes well good sense,have you done it before? dannc
  1. Replacement of Inside Door Handle - VT
    By VT_Boi in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-12-2007, 04:27 PM
  2. Rubber Inside Door
    By red rock in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2006, 07:48 PM
  3. VT inside Door lights??
    By blunt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-01-2006, 10:48 PM
  4. Inside door locks
    By Conan 12 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-11-2005, 04:55 AM
  5. Rattle inside door on VS
    By ntl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-10-2005, 07:30 PM
