Results 1 to 5 of 5
Thread: Passenger Door Lock-Out
    Holdfast is offline Donating Member
    VE & VL
    Jan 2005
    Question Passenger Door Lock-Out
    Guys, seems simple enough question, but my front passenger door won't open at all neither by inserting the key or trying to open from the inside of the car!
    How do I get the car door open so that I can fix the lock?
    H
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    with great difficulty I would imagine!
    pull the weather strip off the outside of the door grab a torch and see if you can manipulate the lock from the inside using a screwdriver or piece of wire, if the security plate is still in the door it may not be possible, alternatively you should be able to remove the inside door trim (not easy).
    Nobody wants to play with me
    VE & VL
    Jan 2005
    Default Any Other Ways
    jatsvl
    Cheers thanks for your reply mate.
    I'll try your suggestion tomorrow and report back.
    Is it, the actual lock that is at fault or perhaps something else?
    H
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    The lock will not unlock if the rod from the inner door handle to the latch inside the door is bent. Try taking the screws out that hold your inner door handle in place then see if it will unlock.
    VE & VL
    Jan 2005
    Tree Cutter
    Thanks mate, I'll try that tomorrow.
    H
  1. passenger door lock is rooted, HELP PLEASE
    By xxNoblexx in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2010, 07:47 PM
  2. Passenger door lock siezing
    By Ramsey82 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-02-2010, 02:49 PM
  3. ignition/steering lock problems passenger door lock
    By timbuk3 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-02-2010, 08:21 PM
  4. Help? Passenger side door handle doesn't lock
    By rch-13z in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-07-2009, 12:21 PM
  5. Broken passenger door lock
    By VRFURY in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-04-2006, 03:01 PM
