Results 1 to 17 of 17
Thread: Leaking tail lights. help please!
    VQ Statesman Series II
    Apr 2010
    Default Leaking tail lights. help please!
    The seals around my tail lights are ****ed and leaking, just wondering if the only way to fix this is with new tail lights? i have been told i can't buy just the rubber seals...
    VL V8 & supercharged VX
    Nov 2006
    western vic
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    this is a very common problem and not just with the vl.
    as blueV8vl has said, or the most common way is to get a 3-5 mm drill bit and drill the base of the lenses so the water drains away, and I know you can't get just the seal if you can it would probably be cheaper to buy new tail lights.
    Nobody wants to play with me
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    thats what i have done for both my lights was fillin up with water when i got it and my vl b4 this one was doing it as well
    2 small holes under neath like Jat has stated and all good.
    Apr 2010
    the taillights weren't filling up, it was going straight though into the boot. I got new lights with seals and it's now happening even worse...
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Quote Originally Posted by jatsvl View Post
    this is the best solution. if it is going in your boot as you say then you need to sort out your boot seal.
    Apr 2010
    Doesn't seemed to be the boot seal. The other day i poored water on to the taillights, and it went straight through the rubber and into the boot..
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Apr 2010
    whats the best way to silicon it? should i take the lights off and put silicon around the seal the place them back on?
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    for a cleaner finish it would be better to remove them and then stick them back in, make sure you clean both surfaces with metho or similar so the silicone sticks good.
    VZ HSV Senator, VL calais RB25 turbo
    May 2010
    Norsey
    i would also just double check how tight you did them up.
    i put new lights in mine once and was worried about breaking
    the mounts. they can actually get pretty tight though as i found out.
    good luck
    Dec 2009
    Use a non hardening sealer like a windscreen sealer otherwise you will have a bigger of a time getting them out in future i you need to.
    Apr 2010
    Thanks for the replys!
    I'll try silicone soon when i can have my car in the garage for the full day.
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    rubber seals are around on ebay, they come with new tail lights..
    Silicone is messy, lol
    Have Fun.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
  15. #15
    Apr 2010
    Yeah I got new tail lights and rubbers but the ****ers are still leaking!
  16. #16
    87-88 Calais executive
    May 2010
    I foun in mine that the metal rim on the part of the boot closest to the rear window, had rusted away under the seal letting water into my boot, in the process of getting some silicon to patch it up. Sick of bailing out water after a wet day.
  17. #17
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    haha i had that with my old vl... just ended up pulling out the rubber grommets in the bottom so water went straight through, i did rebuild the lip with bog and sand it so the rubber seal clipped back on it but it was dodge. minimized it though
  1. Leaking tail light/Boot.
    By vps231 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2010, 04:49 PM
  2. thinking about buying tail lights and or head lights for my VX SERIES 2
    By Silenced in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-01-2010, 09:07 PM
  3. [SA] Vs Tail lights & Tinted Vp rear tail lights and garnish
    By hothousevn in forum Parts And Other Items For Sale
    Last Post: 23-10-2007, 01:46 AM
  4. VS ute leaking tail lights
    By evil_monkey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-08-2006, 11:21 AM
  5. Leaking Tail lights. Common Prob?
    By 1vngal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2006, 11:24 AM
