Results 1 to 4 of 4
Thread: VL Vents not blowing
    VR CALAIS
    Mar 2010
    Default VL Vents not blowing
    Hi guys,
    My Vl vents blow piss weak in the cabin. I mean the face,demister,and side vents blow realy soft when on number 4. But the footwell vents blow all the time when the fan is on. I took the control unit out today and there were 1 vaccumm hose on the back. Could this be it? I dont know where the lines go because i dont know wat number the vac lines are.
    Any help people!
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    do you here a hissing sound from behind the controls when driving? there are about eight vacum lines on the back of the slide switch that all need to be connected, if the numbers have come off it will be trial and error to find which one goes where. and you should check that the line to the vacum ball is connected (behind front left side of the bumper.)
    Nobody wants to play with me
    VR CALAIS
    Mar 2010
    the line to the ball is conected, the lines were tied off when i got the car when the idiots put the head unit it. when i start the car with the lines untied there is one hosse that hisses. Where does that one go? How do i try each line?
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    that hissing line is the feed vacuum for the whole unit to work from the engine .... it will go to one of the pipes on the back of the control until switching disk,,,,
    cant remember from the visual im my head i think it is a longer pipe from unit.... should be only one unplugged hose there put it back on and try it out..
    trial and error buddy
    goodluck
  1. help with A/C vents
    By gottavecalaisv in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-12-2011, 03:07 PM
  2. Air vents
    By MovieDude in forum VE Holden Commodore (2006 - ?)
    Last Post: 15-03-2010, 08:41 PM
  3. VY Ute air vents
    By vy_storm in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-02-2006, 11:33 AM
  4. Air Vents
    By wooly72 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-12-2005, 03:49 PM
  5. vents
    By justbad4you in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-10-2005, 01:33 AM
