Results 1 to 19 of 19
Thread: New deck won't fit in dash
    VL Commodore SL
    Aug 2005
    Default New deck won't fit in dash
    Hi there
    I just bought myself a new stereo for my VL but have found to my dismay that there's not enough space behind the hole where the old stereo was to slide the new one all the way in. It protrudes about an inch from being in the right spot. Anyone got any ideas as to how to get around this problem?
    Thanks.
    VL to VS
    Mar 2005
    Default yer..
    mine had the same prob, caused by the rca's n antenna plug.
    if that's the prob, get some right-angled leads, that solved my prob.
    otherwise, might needs take out the a/c, or put it down low like jetspin _vl did. think u needa part of a calais dash to do that tho? not too sure
    attatched a pic for u to have a look at anyway, compliments of MR jetspin_vl of course
    Attached Thumbnails Attached Thumbnails New deck won't fit in dash-jetspin_vl.jpg
    VS Commodore Omega
    Apr 2005
    That looks cool in that position, is that standard with any of the VLs or just a coincidence/made it go there sorta thing?
    VL to VS
    Mar 2005
    pretty sure it's just been made a convenience thing these days.
    1987 was a long time ago to be thinkn bout mp3's n plasma's...
    not to mention how far the olsen twins have come...
    da-doing-doing, doing
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    You can grind out the bit of the dash a bit and get it to fit a touch easier.
    VL Commodore SL
    Aug 2005
    The radio I bought fits in the hole fine, but I can't slide it all the way back as it hits the aircon (or something).
    At this stage the best suggestion i've had is to pull the security sleeve out a bit (to a point where the radio clicks in to it properly) and then pop-rivet or screw it in to the dashboard - it's probably the way i'll go unless I hear any other ideas
    Thanks.
    Quote Originally Posted by bextor84
    Bax
    Nothing
    Jan 2004
    QLD
    Yeah I know what your talking about, but I'm still saying if you grind a lip off the insert, you can use the strap to get a different angle on the stereo. So it doesn't poke out. That combined with 90 degree adaptors and it'll sit flush.
    VL Commodore SL
    Aug 2005
    Hi
    What strap would you be referring to? Sorry, i'm a bit of a n00b when it comes to this stuff
    Bax
    Nothing
    Jan 2004
    QLD
    The metal strap that comes off the back of the headunit, if thats what your choice of keeping it held in place is. You just put the strap in and you help get a different angle. Which then instead of poking out at the bottom. Sits in level.
    VL RB30 Berlina
    Nov 2003
    the bottom dash bit that jetspin has is a berlina/calais thing......you can get one for about $40.....but i saw a brocky that had a old equaliser(standard)that was made for that purpose........if you can find one of them it would be better
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    you need to cut the angled plastic edges off the dash surround/fascia for it to fit. the metal bracket behind may still have the original screw or even original tape deck back support hanging off it which requires the screw to be chiseled off. easier than sitting there with an angled screw driver trying to undo it a mil at a time.
    VL to VS
    Mar 2005
    i believe he said it's not DEEP enough?
    am i wrong?
    ...aS thE fOruM JunKie StRikEs aGaiN!...
    Blurry Guest
    he means that if you grind away the two lips either side of the dash facia you can angle it down, thus causing rca cables and all that other shit to miss the air con box and sit in there happy like.
    like so, (sorry for the small pic but im sure u get teh idea)
    i suppose it would depend on the deck but myn coveres all the rough edges around the out side so it looks smick. and it should clear, in running 8 rca leads and the arial plug out the back of my deck.
    Bax
    Nothing
    Jan 2004
    QLD
  15. #15
    VL to VS
    Mar 2005
    ahhhhhhhhhhhhhhh
    i can see clearly now... that blurry's here
  16. #16
    VL Commodore SL
    Aug 2005
    Quote Originally Posted by Blurry
    Unfortunately the deck is still too deep for the hole, even with these modifications. (I already did these when I installed the old deck) - it's simply a case of the new deck is just too deep to fit properly.
  17. #17
    rattattack1313 Guest
    Cool
    you can only do the best you can mate....my Panasinic pokes out a coupla mm ...(cos my hands are too big to bend all the cables at the right time inside the cavity)........I am going to mask it up and spray the exposed bits black....one day sooon.....
  18. #18
    VL
    Jul 2005
    Cool
    Try the wrecking yards mate......
  1. New deck
    By DANNY8 in forum Car Audio
    Last Post: 12-09-2007, 07:59 AM
  2. Pioneer CD deck $50
    By PaRaDoX in forum Parts And Other Items For Sale
    Last Post: 03-10-2006, 05:14 PM
  3. mp3 player to deck?
    By padrickz88 in forum Car Audio
    Last Post: 02-10-2006, 12:02 AM
  4. Big Deck
    By AirStrike in forum Jokes/Humour
    Last Post: 15-07-2006, 03:26 AM
  5. CD Eurovox Deck
    By Green machine in forum Car Audio
    Last Post: 13-08-2005, 08:19 PM
