hi there i have a 1987 vl im having troubles with my injectors thay are not squirting fuel. i have changed all the injectors and well still the same problem i have tested the switches and still not working and i have also used a test light on it it has full constant power when unplugged and well i plug it in no power even when i tern the car over
Have you got fuel pressure. If you have got fuel pressure then it could be a crank angle sensor problem. Also check that the rotor is turning in the dizzy when you wind the motor over. You could have a broken timing belt.
yep fuel goes strait to the injectors dizzy in new I'm thinking its a computer problem i have never seen the car run i got it for free like it is now not running
