Results 1 to 12 of 12
Thread: Vl still missfiring?
    Vl turbo/ vn supercharged
    Apr 2008
    Kwinana, Perth
    Default Vl still missfiring?
    G'day, the Vl is still missfiring intermittantly under loa? Have replaced coil, fuel pump, fuel filter, checked dizzy cap and rotor, checked codes.... all good. It runs fine almost all the time.... does this, then is fine again? Any help appreciated. Cheers
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Does your speedo needle flicker at all when it misfires? A VL that i once owned started surging and running real bad when accelerating and i noticed the speedo needle jumping up and down at the same time. It only happened at certain speeds and not all the time. I replaced the speedo cable and it was fixed.
    It could also be your air flow meter or wiring to it.
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    is the firing order correct?
    Quote Originally Posted by BIGbrown1 View Post
    Hey dea, financed my VS 3yrz ago, desper8 4a car, meter read 214,016kms... I PAID $14,000.00, 3yrz l8r im dealin with alot of problemz... n e cheap BUT good mechanix in west melbourne? n e info appreci8d... Fanx...
    Quote Originally Posted by Menace38L View Post
    yea if i end up getting it il lay low from the cops lol jus want it for skids etc lol
    vl berlina wagon 6cyl
    Jul 2005
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    try another CAS and Air flow Meter...
    underload usually is Plugs or leads Plugs gapped to (1.1).. could be a few things else though
    Vacuum leaks/Air leaks in Intake piping,Fuel Reg, Fuel filter, Corroded wiring somewhere causing intermittent problems, go over whole bay...
    Let us know Goodluck
    Nothing too drastic Rb30's are simple fixes :P
    vy2 clubsport
    Feb 2008
    adelaide
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    Yeah i agree, Replace leads with new ones if that dont work, try another air flow meter. if not replace CAS with new one and plug. Try replacing 02 sensor. Check all wiring plugs for corosion, unplug and plug back in.
    What are your terminals like on the battery??
    Whats all your earths wires like? this can cause things aswell!!!
    Cheers Nackerz
    2006 VZ SS Thunder 6.0
    Sep 2008
    Mornington Peninsula
    Apr 2008
    Kwinana, Perth
    Thanks for all ur info guys, have replaced leads, plugs, coil, fuel pump, fuel filter, dizzy, cap. And the ecu is not throwing any codes at me either? Will post woteva it ends up being. Cheers
    Apr 2008
    Kwinana, Perth
    Default Vl still missfiring...worse now:(
    Ok, here's the deal so far.....checked codes and replaced ecu, changed leads,plugs,fuel filter,fuel pump,checked dizzy and cap,replaced power transistor, replaced air flow meter, replaced coil, checked all wiring plugs and battery terminals for corrosion and looseness, For the first time the car actuall died today,and wouldn't start for a couple minutes? Haven't changed the cas, but thought it wouldve died completely and/or thrown a code? The car drives again now, just back to the orig symptoms and a bit more frequent.? Any new thoughts? Cheers.
    VB SL/E
    Dec 2008
    I had an aftermarket replacement ignition module that missfired at 3000rpm, drove fine under that, took it back and exchanged it for another and all good.
    I would also check fuel pressure as per OEM, meaning both running and shut off tests.
    vy2 clubsport
    Feb 2008
    adelaide
    99% gauranteed to be the c.a.s i reckon
  1. Vl Missfiring under load.
    By Jordo2 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-06-2010, 11:11 PM
  2. Missfiring Issues
    By Commy1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-04-2010, 05:45 PM
  3. vs missfiring problem
    By aussielyn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-02-2010, 11:21 PM
  4. Vn Missfiring??
    By VHSLX3300 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-11-2006, 09:53 PM
  5. Missfiring under load??????
    By slick_red_VN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-01-2006, 07:55 PM
