Results 1 to 7 of 7
Thread: trans or tailshaft shuddering?
    1987 VL commodore RB30
    Jun 2010
    adelaide
    Default trans or tailshaft shuddering?
    i bought a car off a mate, we are both tryin to fix it up, while im trying to save for other expenses on it. back it the day, its was running fine until one night he had a full car and tryed to do a burnout, but dumped it to first from neutral while reving it. and ever since that when you accelerate the car starts to shudder. im pretty sure that the trans isnt slipping. so im hoping its the tail shaft or maybe even a bent axle. im not sure. we need to find the problem before we start pulling everything apart.
    its an auto by the way, and if you drive it like a manual the shudder isnt as bad. e.g. 1,2,D
    any ideas on what it could possibly be?
    thanks.
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    maybe your trans mounts, have alook at the back of the trans and the cross member the trans should be about 1 1/2 inch above the crossmember.
    Nobody wants to play with me
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Neutral Dump LOL
    one way to smash ya trans, As stated above,
    if it was a bent axle it would shudder all the time(unlikely)
    centre bearing, Unis, Mounts like the boys have stated
    goodluck let us know
    VL Berlina
    Aug 2005
    Check out your centre bearing between the front and rear propeller shafts. The centre bearing is encased in a rubber mounting which deteriorates over time. If the rubber casing has broken away then this may be your problem.
    Jun 2010
    adelaide
    Jun 2010
    adelaide
    thanks so much guys, i checked it out, and the trans mounts were completely shredded. centre bearing and unis is fine.
    thanks again
  1. shuddering vs
    By plookyvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-03-2009, 11:24 AM
  2. VL shuddering.
    By langer_and_mash in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-11-2008, 06:13 PM
  3. separating tailshaft and tailshaft lengths
    By dans_vz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2008, 08:18 AM
  4. Shuddering on take off
    By inoutinout in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-09-2007, 07:46 AM
  5. VR Shuddering at take take off
    By wakesetter_boarder in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-08-2005, 01:36 PM
Tags for this Thread
