Results 1 to 3 of 3
Thread: fuel pumps not arming & ignition not kicking
    1995 VS Executive
    Mar 2009
    Default fuel pumps not arming & ignition not kicking
    hey all , just completed my A8 and MX7 maunal conversion,
    the car i have put it all in has an immobiliser on it and it seems to be working fine but it also may be the very reason.
    other things i have thought of is maybe the auto plugs left on the loom need to be looped so that the car thinks it is in "Park"... but in saying this i am running a manual PCM so this should not be a problem should it ???
    any help would be much appreciated !
    cheers
    trav
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    even thou you are running a manual computer you still need to bridge the neutral start relay near the battery.
    Nobody wants to play with me
    1995 VS Executive
    Mar 2009
    bridged the neutral on the auto loom and starter motor kicks over but fuel pumps will not work nor is the ignition (no spark) few guys on calais turbo said to bridge the two purple wires from the relay next to the batterery so i will try that tomorrow and see how i go .
    thanks for the help tho jatsvl appreciated
  1. are vn fuel pumps the same as vl
    By dumpd6 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-04-2011, 07:21 PM
  2. vq v8 fuel pumps
    By clubsport_replica in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-04-2009, 07:53 PM
  3. VZ fuel pumps
    By jbanks in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-01-2009, 06:16 PM
  4. how much are 5.0L fuel pumps(for VS)
    By shanhsv in forum V8 Development and Modification
    Last Post: 26-10-2006, 12:20 AM
