Results 1 to 20 of 20
Thread: fuel/air mix is too rich?
    tysonVL's Avatar
    tysonVL is offline L Plater..
    VL sl
    Nov 2009
    Question fuel/air mix is too rich?
    hey guys,
    discovered that my car is running to rich on fuel and don't know how to change it?
    eg: very strong fuel smell from exhaust
    please help!
    thanks
    Quote Originally Posted by Troy711 View Post
    As far as I am concerned the above mentioned styles are nothing but aids infested garbage. Especially speedcore.. when I hear it it makes me want to fist fk my grandmother with a barbwired glove.
    tysonVL's Avatar
    VL sl
    Nov 2009
    not even sure if this is something you can change?
    I have no idea!
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    Could be airflow meter playing up, or another major issue could be coolant temp sensor. These two items can play havoc with mixtures. Easy to swap for another airflow meter to see if that is the issue, otherwise could be coolant temp sensor giving wrong signals to computer and it thinking the car is still cold and throwing in abundant amount of fuel even when engine warm.
    vl berlina wagon 6cyl
    Jul 2005
    its normal for the inside of the tailpipe to be black when using unleadsd
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    tysonVL's Avatar
    VL sl
    Nov 2009
    seems like I've got some work to do then..
    HoldenOnn's Avatar
    May 2009
    Busselton, WA
    I only recently sold my VLT which did 10's on quarter. I have not been without a VL for the last 15 years until now. There are many things that can cause your problem. You just have to work through them one by one. Goodluck.
    tysonVL's Avatar
    VL sl
    Nov 2009
    Forgot to mention, bought new spark plugs the other money, maybe 1-2 months ago, the car has barely been driven, but when I went to check the spark plugs the other day, they were all black! does this have any relationship to the richness of the mixture?
    HoldenOnn's Avatar
    May 2009
    Busselton, WA
    Quote Originally Posted by tysonVL View Post
    Yes. Massive relationship. Like hand in hand. Spark plugs are normally a good indication of engine mixtures. We already know your car is rich, now go and undertake all steps one by one to eliminate issues.
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    tysonVL's Avatar
    VL sl
    Nov 2009
    by cleaning the o2 sensor, could this maybe fix the problem..?
    because new o2 sensors are like $150...
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    possibly but i would think it has become sooty from the other means,.... (Coolant Temp Sensor, Air leak in intake pipeing after AFM, Vacuum Leaks, Leaking injector, AFM not set Properly to right spec (Ohms 375 Resistance is factory) Blocked Air Filter)
    U will have to go over it all starting with cheapest part and work up.
    Goodluck Man let us know
    tysonVL's Avatar
    VL sl
    Nov 2009
    Quote Originally Posted by detox_nath83 View Post
    oh god, any idea's on where to start or a fairly sure way of finding out what the problem is exactly?
    I'm 16 and don't have a job at the moment, doubt my parents will pay either.
    need to get it fixed asap so I can get my hours up!
    VZ HSV Senator, VL calais RB25 turbo
    May 2010
    Norsey
    checking your intake pipe for leaks or blocked filter is obvously the cheapest been free. if any mates have a vl try there AFM. better then buyin one for nothing. then id say check your injectors for leaks. then coolant temp sensor, o2 sensor and so on after. goodluck
  15. #15
    HoldenOnn's Avatar
    May 2009
    Busselton, WA
    Cmon mate, we are going around in circles. We have given you heaps of info to go on with. Also, do yourself a favour and go and buy a Gregory's VL Service Manual and have a read. 15 years ago when I bought one, I had a read and everytime I learnt something new. To this day I still have it, and I have just recently sold my 10sec VL but I still use or lend out my Service Manual as one of my best mates has just started the VL owning cycle
    15 years of VL's and there are always many options which could be causing an issue. A process of elimination buddy. Goodluck.
  16. #16
    VB SL/E
    Dec 2008
    Quote Originally Posted by harry3 View Post
    Might be what your used to but you can tune it out of it if you prefer not to run so rich.
    I had my VL running with a grey tinge.
    To OP, have you checked the fuel pressure yet?
  17. #17
    tysonVL's Avatar
    VL sl
    Nov 2009
    hey all!
    just updating you, there is no leak in the air intake piping and the air filter is fine!
    The distributor cap was a bit clogged with gunk shit but that came out alright and it seems fine now apart from a bit of wear.
    NEW SYMPTOM!
    This started happening the other day, when idleing, after about 10 seconds the revs start dropping until it completely cuts out. Clutch in/out does not affect this, stationery or not doesn't affect it either. when the accelerator isn't keeping the revs up, it will slowly die.
    is this related?
    thanks!
  18. #18
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    fuel pressure erg my vr does the same thing its th e pressure reg flooding the car and allowinng fuel in threw the vaccum line try that out
  19. #19
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    unplug your AFM and try start the car if it starts and idles the AFM is stuffed., plug it in while it is running and it starts doing what it has been doing the Afm is the problem.
    Process of elimination Man
  20. #20
    tysonVL's Avatar
    VL sl
    Nov 2009
    Yeah, did that the other day, it's not the problem. Made no difference whether it was plugged in or not.
    So, I now know it's not the following are all fine:
    - Distributor cap
    - Intake piping between AFM and throttle body
    - Air filter
    - AFM
    Leaving possibilities of:
    - o2 sensor
    - Leaking injectors
    - Coolant temp sensor
    - Fuel pressure regulator
    - + others probably
    I got suspended for 2 weeks from school, so I'm going to have heaps of time on my hands, but I won't have my dad around to help me.
    Hopefully i'll be able to get this sorted by myself, or at least find the problem!
    Got one of those Gregory's VL service books off my Uncle the other day, seems very informative!
    Tyson.
  1. I'm going to be rich
    By Dayvo in forum Jokes/Humour
    Last Post: 05-11-2009, 09:05 PM
  2. Running Rich
    By ash72 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-03-2008, 06:00 PM
  3. Rich exhaust
    By ukgts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-02-2007, 05:51 AM
  4. Running Rich
    By stagg in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-07-2006, 10:04 PM
  5. running rich
    By canb_vn06 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-07-2006, 09:44 AM
