Results 1 to 5 of 5
Thread: Vn- Vs live axel V8 Diff into Vl
    88 VL Turbo SL and 86 VL SL
    May 2010
    VIC
    Default Vn- Vs live axel V8 Diff into Vl
    Hi has anyone ever fitted a Vn - Vs live axel Vn diff into a vl.
    I know that you will need a disc brake handbrake cable but what about the brake fluid lines will they need to be extended or will it just bolt up.
    Also would you need to add a 1" master and booster to avoid spongy brakes ?
    thx.
    VK V6
    Mar 2010
    NZ
    You need to alter or replace the proportioning valve inside the master cylinder (or replace the whole master cylinder) with one to suit four wheel discs if converting from rear drums. You don't need a 1" master, the standard one will be fine as used by the factory with the same rear disc brakes from VB-VS. With the disc brake hand brake cable everything will just bolt up, but the VN onwards diff is around 40mm wider so will only fit properly with relatively narrow wheels and tyres.
    LUMPY 8's Avatar
    LUMPY 8 is offline buddaboy1990
    VK V8 WAGS, The bannana (vp calais donor), VS BT1
    Nov 2007
    SAs biggest retirement village (victor harbor)
    is it 40mm wider on each side or all up? Im asking because i have some 17s on my wagon but they scrub on the wheel arch on the inside. (not the guard if ya know what i mean)
    Wrecking VL factory V8 only a few bits left still have full dash/crash pad
    and have a vk 202 motor and 5 speed Make an offer want it gone
    vy2 clubsport
    Feb 2008
    adelaide
    VK V6
    Mar 2010
    NZ
    Quote Originally Posted by buddaboy1990 View Post
    All up, 20mm(ish) per side
  1. How do i tell between IRS or live axel
    By Riordan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2010, 12:36 PM
  2. Live Axel or IRS on S-Packs?
    By HamaTime™ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-09-2009, 11:21 PM
  3. [VIC] WTB lsd diff live axel for vn
    By NEDWOB in forum Swap / Wanted to Buy / Trade
    Last Post: 15-06-2009, 11:40 PM
  4. [VIC] WTB - FE2 Springs live axel
    By -=ApheX=- in forum Swap / Wanted to Buy / Trade
    Last Post: 19-01-2009, 01:08 PM
