Results 1 to 2 of 2
Thread: n/a injectors and ecu in a highcomp turbo motor
    88 VL Turbo SL and 86 VL SL
    May 2010
    VIC
    Default n/a injectors and ecu in a highcomp turbo motor
    Hey guys i have been told that n/a rb30 injectors will work with the n/a ecu with a highcomp motor even with boost levels off above 10psi however.
    One person claims that they have run there vl with n/a injectors and ecu and that the injectors run out off pressure or something like that after 7psi and that its unsafe to push them beyond 10psi unless you want to melt your pistons. Is that true ?
    Another person i spoke too mentioned there mate runs 10 psi with no cooler with nothing more then vlt injectors and vlt ecu and that it can still do a mad dose ? is this guy full off s**t or is it really possible because i allways though that you need a intercooler to be able to run past 7psi and to use with a dose pipe.
    Thanks.
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    i am running 6 psi with my setup with intercooler, i have not tried any higher as i have heard of them maxing out at 7psi as well.
    but i do have Turbo Injectors and Ecu here ready to go in.
    with the right tune and so forth he might be running 10psi (timing/afr's etc/Right fuel)
    Forget the dose really.(just a piece of pipe off the turbo compressor intake, so it amplifies the compressor surge)
    Sacrificing the Air filter for a dose pipe it silly
    U Can put a stocking over the pipe end.(or a Pod filter)
  1. Rb30e to Rb30et (Highcomp)
    By M3ZZA in forum VL Holden Commodore (1986 - 1988)
    Last Post: 16-03-2012, 11:36 PM
  2. [SA] vl turbo motor/trans/microtech/fmic/gtr/plenum/turbo + vs v8 5spd conversion
    By nasty1 in forum Parts And Other Items For Sale
    Last Post: 18-05-2010, 07:58 PM
  3. Few Conversion Questions Fellas N/A - Highcomp Turbo
    By detox_nath83 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-12-2009, 07:50 PM
  4. [NZ] WTB L67 or xr6 turbo Injectors (set) from Anywhere
    By Nzpure in forum Swap / Wanted to Buy / Trade
    Last Post: 15-08-2009, 07:29 PM
