SKF
Deep groove ball bearings, single row
6000-2RSL (this is the bearing designation I found on the SKF website)
(I thought is was SKF 6000-2RS1 as I saw in a photo of the bearing in the CAS kit)
Is this code the same as what comes in the kit?????
10mm diameter inner / 24mm outer / 8mm high
SKF is everywhere in Australian and I want to buy the bearing for less than 10 bucks before I buy a light emmitting diode (LED) that cost 140 bucks only to find that the bearing is the dust maker that is stuffing up the light beam. The black plastic ones are meant to be taiwan ones - silver are meant to be the better sensor????
