Results 1 to 8 of 8
Thread: Guzzler !
    Ke30 Rolla'
    Oct 2009
    RAD-elaide
    Unhappy Guzzler !
    Hey guys, long time since i been on here..
    Ive had no problems with the wagon, engine wise, there is a thing that is bothering me tho.
    Fuel consumption, im getting around the 17L/100km even if i grandma spec drive the car.
    No missing, not lean, or rich, nothing i can think of
    any suggestions ?
    Quote Originally Posted by minux
    HAHAAHHAHAHAHAHAHHAHAHAHAHHAH
    Wanker.
    vl berlina wagon 6cyl
    Jul 2005
    if the engine temp sensor fails, the electronics think the engine is cold all the time so it runs rich, also the lead can fall off it
    Ke30 Rolla'
    Oct 2009
    RAD-elaide
    Its running at normal temp too.
    Every thing is perfect, runs super well, just so fuel thirsty.
    Wanker.
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Try a new fuel filter. Another problem is that fuel return lines can go brittle and leak back near the fuel tank so your fuel runs out onto the ground.
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    have you checked ur tyre pressure? if its low it can affect ur fuel eco
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    VT spac super6
    Nov 2008
    Riverton sa
    VH SS
    May 2009
    Toowoomba, Qld
    17L/100 - is that around town, highway or mixed ?
    If it's using too much fuel, then generally speaking it's running rich
    check the airflow meter adjustment.
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Please do a search man this has been covered many times.
    U r saying that the Gauge is showing fine temp...
    Well there is 2 Sensors
    One for the Gauge(1 Black Wire) (where top Radiator hose goes to the Engine)
    Next to it is another Thermo for the ECU to read 2 Wires in a plug.
  1. Gas guzzler
    By londongeezer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-10-2005, 09:48 PM
