Results 1 to 2 of 2
Thread: injector seals
    vlrad Guest
    Default injector seals
    I'm going to pull my injectors apart and seal them up with some gasket gue around the normal seals.
    Where the bottom of the injector sits on the manifold is no worries as this is atmospheric pressure - same as the pressures experienced by gue on manifold to block interface.
    Where the injectors sit in the injector holder - is this under fuel pressure or does the c clip take some of the pressure???? Is this normally a dry fit?? If the o seals are under pressure and exposed to fuel - Is there a sealant that was meant for fuel and a little bit of pressure? Will normal gasket gue work for a few weeks or months or years.
    Relpy if you have done this sort of work - help appreciated
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    Just replace the o rings, & hoses, DONT under ant circumstances use any sort of "gasket glue" on them, they will seal correctly if you replace the seals properly, if youre not confident get it done professionally, id hate you to have a fuel leak & fire under the bonnet
    Rob
  1. WTB: Vn door seals
    By Ygoford in forum Swap / Wanted to Buy / Trade
    Last Post: 08-12-2006, 10:39 AM
  2. seals broken
    By VLACS in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-01-2006, 09:23 PM
  3. door seals
    By timboss04 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-08-2005, 09:11 PM
  4. window seals
    By sparkymac in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-06-2005, 04:19 PM
  5. Windscreen Seals
    By Mad Dog in forum VL Holden Commodore (1986 - 1988)
    Last Post: 16-03-2004, 05:56 PM
