Results 1 to 3 of 3
Thread: head warping
    vlrad Guest
    Default head warping
    If a take a head off an old RB motor and put it on another - is there anything to be careful of??? Will it warp anymore than other engine heads
    VL Crapbox
    May 2005
    Do it slowly is the best way, make sure its cold and then 'crack' each bolt first by turning maybe 1/8th a turn each , starting from front left, go back right and then front right, back left and work way in. when finished, stand it up on end or leave on perfectly flat surface, this way you should be right. then undo all of em.
    If you want more inches, STROKE IT!
    vl berlina wagon 6cyl
    Jul 2005
    if the old head warped thru overheating, remember the bleeder screws
    come to think of it with the steam trap operating, and overheating happening, the temp gauge may not show a high reading??
    any comments......
  1. Cracked head? blown head gasket???
    By VL_5SPEED in forum General
    Last Post: 09-01-2010, 10:41 AM
  2. 186 head on a 202? ( red )
    By V3N0M in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-06-2006, 06:22 PM
  3. Blown head gasket or cracked head
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-06-2006, 07:52 PM
  4. new key + key head
    By crainy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2006, 11:01 PM
  5. Head job
    By SNY.3LT in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-11-2005, 12:27 PM
