Results 1 to 7 of 7
Thread: VL 6liter V8?
    Walky replica
    Aug 2010
    Default VL 6liter V8?
    Hi guys,
    Just wondering if any 1 has herd of a VL with a ls2 or l98 6.0 yet?
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    Walky replica
    Aug 2010
    Walky replica
    Aug 2010
    Default 6l vl
    Quote Originally Posted by Nackerz View Post
    yep its been done before!
    do you know anything about the build? e.g. sump, wireing, speedo, custom mods?
    Vk ls1 turbo
    Aug 2009
    townsville
    the main problems would be power steering rack hitting the alternator and extractors on the drivers side will need to be custom made to fit. Also might have a problem fitting gear box but can be fixed with a grinder and welder. also make sure you do research on which conversion kit you use eg mounts and what not because alot of people have had problems with off the self stuff. it will be the same as fitting the 5.7 to a vl pretty much. do some research on it there is heaps of info around
    2002 HSV GTO COUPE
    VK calais ls1 turbo conversion (in the build)
    2009 turbo v8 landcruiser
    My VK http://forums.justcommodores.com.au/...-vk-355-a.html
    Walky replica
    Aug 2010
    Quote Originally Posted by 21sly View Post
    I've got my self an L98 6.0 out of a VE ssv, I will be making all my custom engine mounts, extractors, starter motor mount, gearbox mount, and mybe sump mods. I wish I could see 1 already done...
    Vk ls1 turbo
    Aug 2009
    townsville
    there is a few guys over at calaisturbo and ls1.com doing them as we speak and other threads with complet build ups mate google ls1 into vl i know its not a l98 but same sh!t different smell. plenty of info there so should make it heaps easy for ya mate. will be a weapon once ya done thats for sure. One day when i get a bigger shed i would like to do the same but into a vk. good luck
    2002 HSV GTO COUPE
