Results 1 to 6 of 6
Thread: Heater hose t piece- any ideas on remove
    VL Executive
    Sep 2009
    Default Heater hose t piece- any ideas on remove
    Hi guys
    I have just discovered a hole in the heater hose t piece near the water pump, and can't see how I can remove the t piece. Any ideas- I'm desperate
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    u saying above the Thermo housing there is the Hose that comes in from the heater box(runs along side of block Drivers side) and go behind the waterpump the "T" looking bit and the top hose goes up to plenum???..... i had a leak there so i tapped this piece out and welded the end where my pin hole leak was.,,, tapped it back in being only a knock in piece and has been fine since,? i think i know the bit ur on about but hard to explain.
    Use a piece of timber or a Long Screwdriver and tap it out it only a knock in piece.. not threaded or moulded..
    Goodluck
    Let us know how u go
    VL Executive
    Sep 2009
    Quote Originally Posted by detox_nath83 View Post
    Goodluck
    Hi Detox
    Thanks for your repsonse- just to clarify, I'm talking about the t piece that has a hose from the heater box and another smaller hose going up to the plenum. The leak is actually a small hole ( big enough) just near the plenum hose that has just started leaking like a sieve. The brother and I had a crack at it today and what we did was insert a brass pipe in to the t-piece from the heater end and then stick some metal glue on top of the hole, waited half the day and then stuck the heater hose back on. No more leak. Just on your solution, are you saying the t-piece can be prised off the water pump housing with a screwdriver ? Not sure when you say, you can tap it out.
    After all that, I found another small leak on the thermostat cover ( not detected previously) will give it a crack next weekend.
    Hopefully you can fill me in a bit more- I'd like to know how in the hell you tapped out that t-piece, mine looks pretty much stuck on.
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    yeah man worked from the top and Tapeed it out using a long screwdriver came out reasonably easy...
    i know the one your on about.it is a replaceable piece, it is a Steel(Not Brass, Cos i welded up the hole i had) Piece and tapped in to the rear of the waterpump impellar hole. Mine was leaking at the end of the piece and the barb for the hose for the plenum was also corroded out when i took it off to remove the "T" Piece.
    VL Executive
    Sep 2009
    That is a great photo- says it all, very much appreciated. Drove the VL a bit today, no leaks, but when I find a good t-piece I'll replace the patch up job. I tried a few places like Commwreck ( Melb.) only had two corroded ones, Repco didn't stock, Holden Dealer said it was an obsolete part, so could be hard to find. I know pick a part have about 12 VLs in stock, could be the go.
    Thanks again.
    S
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Not a worry man. yeah i patched mine and i have another on my spare RB30 Im gonna Re-build. Pain in the ass that part
  1. VS v8 Heater hose pictures???
    By rooooboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-09-2009, 10:02 AM
  2. Possible Heater Hose???
    By ceedy_18 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-05-2009, 09:27 AM
  3. VP on LPG heater hose setup
    By fishman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-04-2007, 08:48 PM
  4. VP on LPG heater hose setup
    Last Post: 05-04-2007, 11:30 PM
  5. can anyone help with VP on gas heater hose setup
    Last Post: 15-11-2006, 09:54 PM
