Results 1 to 7 of 7
Thread: light issue
    mrvdv is offline vanders
    VS Holden Commodore
    Apr 2008
    In A Suburb
    Default light issue
    hey all
    I got high beams and parkers but no head lights, there is power going to the relay but there is no power going to the actual low beam fuse. whats the best or wheres the best idea to suss out.
    VT S2 LS1 -VX S2 SS LS1
    Feb 2010
    IPSWICH
    you have power going to the relay but have you checked the relay itself??? pull out one of the other relays & plug it in to see what happens. had exactly the same problem & it was just a buggered relay
    VS Holden Commodore
    Apr 2008
    In A Suburb
    Feb 2010
    IPSWICH
    ok,have you checked the bulbs,as they have two filaments,one for high beam & one for low beam? also check fusebox under the dash
    VS Holden Commodore
    Apr 2008
    In A Suburb
    is there a fuse box in the dash cause my fuses are in the engine bay. and yeah i checked the bulbs and tested whatever i could with a light tester but couldnt get any thing when the head lights are on
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    No fuse box under the dash on the vl... i had this prob and it was in the Main light switch the one that the whole light assembly plugs into.... gave it a wriggle and some INOX and away it was,,,,
    VS Holden Commodore
    Apr 2008
    In A Suburb
    yeah i tried that and still nothing, its just strange... and not sure how long or how much a auto electrician would charge to fix it up
  1. dash light issue.
    By Maccasmack in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-07-2010, 05:47 PM
  2. vp 5.0L has oil light issue
    By VP 5.0 BERLINA in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-06-2010, 08:42 AM
  3. Odd hazard light issue
    By Semaj in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-07-2009, 11:33 PM
  4. Break light issue
    By LUMINA ANIMUL in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-03-2007, 04:28 PM
  5. another light issue!
    By 5spdVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-06-2005, 09:39 PM
