Results 1 to 7 of 7
Thread: Vl ecu
    VX and VL
    Aug 2010
    Default Vl ecu
    I'm putting an RB30 non turbo engine into my Vl with a RB25 head on it, Do i use the standard ecu for the 30 or do i need to get a 25 ecu?
    vy2 clubsport
    Feb 2008
    adelaide
    im gathering you will have the rb25 wiring loom so you will need the ecu im guesing
    VX and VL
    Aug 2010
    Thanx, now i just need to find a RB25 ecu not for turb and wiring loom. It never ends....
    vy2 clubsport
    Feb 2008
    adelaide
    thats why before you buy do a tiny bit of research it will end up costing less in the long run
    VX and VL
    Aug 2010
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    in NZ they would be a dime a dozen as that is the standard VL set up there.
    Nobody wants to play with me
    vl commodore and vz ss
    Jun 2010
    goto a japanse auto wreckers or an engine importers they should have all the parts you need if since ur in perth there is one on william st in cannington called japanese auto wreckers
