Results 1 to 12 of 12
Thread: VR Fuel Pump in VL
    mrvdv is offline vanders
    VS Holden Commodore
    Apr 2008
    In A Suburb
    Default VR Fuel Pump in VL
    hey i just got a VL and was told that there is a VR Fuel Pump in my VL because it kepted blowing the VL ones up.... they had to chop it down or something and was wondering would this make my fuel guage out of whack because my fuel guage had told me i had just over a quarter but then the car ran out of fuel
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    would not affect your fuel gauge as it is a variable resistor with a float.. depends if the VR has an inertia pump(intank pump) or lift pump.
    Is the Fuel pump the highflow pump from a vr??(Not affect Gauge),
    If the vr has an inertia pump with the gauge float in one assembly like the VL one the resistance and readings could be different giving u a false reading at the gauge,.,
    Depends what pump u have.
    VS Holden Commodore
    Apr 2008
    In A Suburb
    yeah i aint too sure on all the technical side of it all, but i know i run out of petrol when the guage is just over a quarter
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    VS Holden Commodore
    Apr 2008
    In A Suburb
    well i swapped the dashes around.. so most likely to be the float/resistor?
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Most likely yes , they arent that hard to change, i have changed a few now.
    Jack the car up
    Axle stands on both sides
    Let the diff down as low as it goes
    Get under and undo the bolt on the bottom to allow any fuel to drip or drain out
    Carefully manovure it out, this is tricky because it is a small space to work with but it does come out and dont force it!
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    it is one piece dude. as in the inertia pump(lift Pump) and sender unit in one. ill get a pic now of me spare. :P so u know what your working with
    VS Holden Commodore
    Apr 2008
    In A Suburb
    so another chance could be that the pump/sensor is the wrong way round giving me a bad guage
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    VS Holden Commodore
    Apr 2008
    In A Suburb
    dunno haha like i havent taken one out before but like say if north goes to north for it to work, and its west to north so it aint working, dunno if i have confused you there
    calais24/7's Avatar
    Jul 2009
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    it will only go in one way dude and u just manouver it back into the swirlpot inside your tank it will not sit flush on the tank to bolt up if u have it wrong.
    and when u think about it, if its upside down your gauge will show Empty when full and Full when Empty. But you cant get it wrong
  1. Fuel Tank,Fuel Pump Assembly and Swirl Pot.
    By Brett_jjj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2011, 10:12 PM
  2. have had to wack the fuel tank to start my car!! is my fuel pump stuffed?
    By CV6Z in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2010, 04:13 PM
  3. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  4. Fuel pump issue, or fuel line blockage? not sure help!
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2008, 02:08 PM
  5. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
