Results 1 to 3 of 3
Thread: VL wont crank over, butwill if wire hooked up to starter from battery
    VR 5L ute
    Oct 2007
    Default VL wont crank over, butwill if wire hooked up to starter from battery
    Hi guys
    Im not a VL owner but my mate has a 1987 VL auto that wont wind over.
    Starter works, batterys good, terninals are fine, ingnition lights work but she wont wind over.
    I checked the relays and fuses and there all good.
    Only thing i can think of is.
    A auto switch is stuffed, like its still in gear but its not.
    B wire going from battery to starter is stuffed.
    When ignition is switched on and i bridge a wire from the battery to the starter it will crank over, start and drives fine.
    Anyone able to pin point any other things that might be wrong with it
    Chears Neil
    VR ute / Vl calais
    Aug 2010
    Queensland
    yeah mate it sounds like the wire from your key to your starter motor is broken or has come off the back of the starter try starting it in N that will tell you if the park saftey switch is stuffed or not but i would be lookin at the wires from the battrey to the key and from the key to the starter motor or it could even be a kill switch that it faulty if the car is fitted with one that is anyways good luck
    VL V8 & supercharged VX
    Nov 2006
    western vic
    yeah i say its the wire from start to key its a common prob in vls.
  1. wont start, starter motor won even try to crank
    By vs1997II in forum Electrical Wiring / Questions
    Last Post: 30-06-2010, 09:31 PM
  2. El Wire hooked into 12volt car power.
    By dark_realm in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-11-2009, 03:12 AM
  3. LS1 crank angle sensor wire colours
    By pedro_nz in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-09-2009, 08:35 PM
  4. little wire on starter
    By hoon1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-09-2006, 12:01 PM
  5. Starter Motor wire
    By Stewart1000 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-08-2006, 07:45 PM
