Results 1 to 23 of 23
Thread: shaved locks?
    stock_vl is offline wh internationals?
    vl calais 3.0L
    Apr 2005
    Tocumwal/isolated
    Default shaved locks?
    ok. i heard of ppl "shaving" there locks.
    is this like just filling in the key hole etc? and then covering over etc....
    like i was thinking about it the other day!
    i dont ever use me locks!
    i have central locking.. whats the point?
    should i cover them over?? would be safer, like from getting stolen!!
    anybody done anything of a sort?
    thanks peeps
    I CANT WALK ON WATER BUT I CAN STUMBLE ON ALCOHOL
    Jules86's Avatar
    Jules86 is offline The Cream Machine
    VL(VeryLow) Commodore Exec.
    Jun 2005
    Rockhampton
    Dunno how often it can happen but what if your c/l plays up? If someone really wanted to get in your car they would, mine have had the old screwdriver behind the lock, wrecked the door, been fixed, and lock covers added, then the screwdriver in the keyhole, then i replaced with solex, dunno how many solex keys are the same, but i can open and start 2 other vl's with my key. Would you plan on doing the boot one as well, same o, wat if the button plays up; they do. If you don't have alarm or imobiliser go ahead, nothing worse than finding out some cu*t has tried getting into your car or worse stole it.
    How good are your breaking into vl skills? if u were to have a prob!
    vl calais 3.0L
    Apr 2005
    Tocumwal/isolated
    lol.. yeh spose!
    they screw up when battery goes flat now i think of it:| lol...
    happened just the other day and i had to use key to get into car:|
    id leave the boot cause there is noway for them to get into car...
    or i wouldnt actully as i can open it with keys by holding the button in
    so yeh and also from inside of car in glove box...
    i would just need some sort of a back up battery for the immobiliser and stuff and i would be set
    i think..
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    Well I'm getting mine done, shaving the lock purely to tidy up the outside of the car - but on the inside im getting a bigger metal bracket welded over the top of the lock mechanism. The one thats there now just isn't any good at all, I mean, I can get into my vl in 20 seconds on my first go. Thats scary.
    Basically you take the lock out, weld a plate behind the door, bog over to smooth it off, paint over. Probably have to get the whole door resprayed if you were to get it looking good.
    I'm leaving my boot lock as the only exposed lock on the car- I was tempted to smooth that aswell. But, battery relocated into the boot in case of flat battery. But if the mechanism itself fails it looks like I'll be smashing a window.
    Dezza's Avatar
    Dezza is offline your local HSV dealer
    Cammed up Vy Clubby
    Feb 2004
    well my mates car the didnt worry bout the lock they crowbared his door open at the shopping centre good thing he had an alarm
    vl calais 3.0L
    Apr 2005
    Tocumwal/isolated
    true that!!
    are you actully putting battery in the boot?? thats a mad idea!! although i would hate to see how 'phat' the wire is you use to take all the leads down there! lol...
    umm thats a mad idea...
    but i dont see how you smooth it over...
    like to smooth it over wouldnt you just fill the hole in thats in the door handles (isnt that where the lock is =s) i cant really remember exactly! therfore you would have to paint and smooth over door handle.. that possible? paint it chrome again? =\
    Bax
    Nothing
    Jan 2004
    QLD
    the door handle stays there man. the lock is seperate and when thats taken out it leaves a hole.
    as for the battery in the boot, you need a battery box, and a new battery, unless you want to put a vent in your boot, which i'd doubt. so you'd get a sealed battery.. few meters of fairly heavy cable and about double that for earthing.
    then you run the positive to the starter motor, then earth it to the floor in your boot, and the block. Then connect all of your previous connections from your battery to the starter. Done.
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    you could still shave your boot lock i reckon bex, keep it all happening nice and smooth.
    ive seen a car with no locks, and to get around the battery problem there were a couple of terminals under the car (it didnt have a relocated battery) so if the batt went flat you just hook the jumps to the terminal clips. i mean for the number of times your car goes flat (hopefully very few!) it would be worth shaving th lock and having to reach under the car to jump start it.
    Since the batt is in teh boot use the section between the lights. A mate hinged his and moved the filler there and smoothed out the filler. i imagine you could have emergency starter clips behind there.
    i think youll get what i mean? i can picture it but might have explained it badly....
    vl calais 3.0L
    Apr 2005
    Tocumwal/isolated
    i know what you mean!!
    thats a mad idea!
    like you could have them just sitting anywhere under the car there! yes its a great idea! would be a bastard if you wont over a bump and the terminals got stuck on each other under the car =\
    lol. thats an easy thing to prevent though.....
    i like that idea!! i really do =)
    Bax
    Nothing
    Jan 2004
    QLD
    Yeah I picture exactly what your talking about. And it may very well be done. It wouldn't be hard, the battery is probably going to be mounted in the spare tyre well. so the connections could be put there somehow.
    VN Berlina
    Sep 2005
    yeah if u dont wanna get ur vl stolen and appart from the vn its the easiest commy to take.. shave ur locks. or evenm just block them up inside so robbers get confused lol...
    -shave the locks, looks good.
    -get central locking,
    -relocate the batery to bypass the central locking locking u out when batts flat
    -get an alarm.
    and get a seperate imobiliser cos its not hard to break a windowe of the coathanger down the window whatever. its realy not hard. but if u have a switch somewhere they dont know then their not getting far atleast
    realy thats not much seing u want to keep ur car...and ive seen some realy nice vls that could very easily just be taken thrashed to hich hell stripped burnt whatever. when a few hundred dollars would make it safer and it does look better and is easier
    but theirs always someone who will just smash ur window steel ur smokes and cds and nick off leaving u with hundreds of dollars of damage and missing shit or just key ur car cos they dont have it... I WANT A FORCE FEILD (idiot trying to get in :b: )
    Bax
    Nothing
    Jan 2004
    QLD
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    yeah i will end up doing the whole lot done, top job alarm system, shaved locks, plate in the door.
    here is an idea about the battery going flat, you could run a small wire from the + terminal and tie it around somewhere at the bottom of the car, then you just need a battery charger and attach positive to that wire and negative to the body. i dont see why you would put the battery in the boot unless it was to clean up the bay a bit, and yeah it would look pretty schmick... get me thinking now... good on ya
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    here is an idea about the battery going flat, you could run a small wire from the.......
    .......which is what i said 5 posts up....4 months ago..... mate.
  15. #15
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
  16. #16
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    do you tell that to all the others? ohh i get it, arking up over my suggesting you get off the capslock. totally different story mate, doesnt alter the readability....... at all.
    edit: and please dont drag little niggles between posts. its not fair on other members or what they are trying to find out.
    I suggested in another post you stop using caps for the whole post, you had a go back at me, it should have stopped there.
    Leave it. dont follow my posts around the forum being a pain in the arse just for the sake of an argument. this sort of thing has had members banned before..... mate.........
  17. #17
    Sep 2005
    Quote Originally Posted by vlv8vic
    Dont get cut. Obviously you cant take a joke! And its allright for you to have a go to have a go at other people like you said here (.......which is what i said 5 posts up....4 months ago..... mate).
    And no, why would i bother to follow your posts!? Who the ***k do you think you are!!!? Get over yourself! And just remember. You started it!
  18. #18
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    Quote Originally Posted by IBLOWN
    a- he constantly repeats what was said only a few posts ago, in threads that are well and truely finished with.
    b- i dont think about who i am, i know who i am, therefore dont have to think about who i might be.
    c- wouldnt this crap have been even when you had a go back at me straight after i had 'started' it? wasnt worth spotting something i wrote elsewhere and making yet another comment.
    d- no need to be over myself, i hold myself in higher regard than you and most other people i know. thats me! im the greatest.
    Its finished with pal. Like you said i started it. so im finishing it. thats it. no more or ill report the posts and have the whole lot removed.
    finito.
  19. #19
    vl calais 3.0L
    Apr 2005
    Tocumwal/isolated
    shuddup mungrels!!!
    i wanted to find out a simple thing without you boys crying a river!
    vlv8 stated the obvious as he had clearly and obviously already stated it in previous posts!
    over yaself IBLOWN
  20. #20
    Nobody Actually's Avatar
    Nobody Actually is offline luxo barge
    VS s2 Caprice 5l = slow
    Aug 2005
    Queensland
  21. #21
    VLT11 Guest
    my door locks and boot lock are shaved and i have 3 remotes for the car anyways so if one stuffs up i can have someone bring me another... as for the batter goin flat or whatever.. its not hard to call RACQ and have then unlock ur car for ya.
  22. #22
    Bax
    Nothing
    Jan 2004
    QLD
    RACQ aren't the only ones that can open the doors that way though. Thats why I reckon you need metal sleeves over the lock
  23. #23
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    might have mentioned this before, but a friend has a couple of wires to the battery termis, to lugs under the front of the car so if the battery dies he can jump charge it without having to get in the car (power the locks up and youre in). he has a little plate over them to keep them safe with a little key to open it.
  1. shaved door handles???
    By vt_on_20s in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-10-2007, 04:07 PM
  2. wtb: shaved doors
    By slayer in forum Parts And Other Items For Sale
    Last Post: 23-09-2007, 08:01 AM
  3. shaved doors
    By slayer in forum Swap / Wanted to Buy / Trade
    Last Post: 24-02-2007, 05:32 AM
  4. shaved heads or roller rockers?
    By Tom04 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-11-2006, 01:37 PM
  5. shaved door handles
    By slayer in forum General
    Last Post: 03-10-2006, 04:57 PM
