Results 1 to 8 of 8
Thread: Release bearing
    VL Wagon 5 Speed
    Sep 2009
    Default Release bearing
    Hi all, hope this hasn't been covered much before..
    Since i got my vl (almost a year ago now) it has a rather loud bearing noise when the clutch is OUT and in neutral,1st 2nd or 3rd.. and a couple of times the car would grind to a halt when changing from 1st to 2nd.
    so the guy at the local garage said it's the spigot bearing which needs replacing, so i got new bearings as well as a heavy duty clutch while we were at it, and the noise is still there, but drivability seems fine for now.. anyone had any thing like this?
    Cheers,
    Tom
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    It must be a bearing in the gearbox. At a guess i would say its the needle rollers that go in between the input and main shaft. If the shafts are pitted where the needle rollers run it will be an expensive fix.
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    1st 2nd and 3rd layshaft bearings in the box
    VL Wagon 5 Speed
    Sep 2009
    hi guys thanks for the responses.
    it shan't be the spigot as the dude replaced that one.. since its possible its inside the box, would you guys go about fixing it or just put up with it?
    cheers
    Apr 2006
    Mt Gambier SA
    If you keep driving it with a buggered bearing in the gearbox, it will eventually strip the teeth off some gears because as the bearings wear the shafts will be forced apart so the teeth of the gears only contact on the tips where they are weaker.
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    VL Wagon 5 Speed
    Sep 2009
    yep, the throw out bearing he also replaced.. going in next week under warranty thankfully.. a righteous joke!
    thx again peepz
  1. boot release
    By VNDUMP"D in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-01-2009, 03:58 PM
  2. hydraulic release bearing
    By strainy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-07-2008, 06:41 PM
  3. Help with VL Boot Release.
    By Brocky_05 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-02-2006, 11:19 PM
  4. Release Bearing Woes..
    By VT-565 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-06-2005, 03:52 PM
  5. VZ Ute Release??
    By Andiesrefuge in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-09-2004, 07:42 PM
