hi guys just got a quick question i had coolant dripping on my foot this morning when i had the heater on im assuming one of the heater hoses is split just wondering if this is a common problem and if it is witch hose usually goes just to save me tearing the whole dash out to find the right one an idea on where to start would be awesome cheers
Hey man on the left side of the drivers side foot well above clutch there is a small heater hose/fitting with a small shutoff valve for when u slide the temp slider it closes the coolant flow to heater box.. Now there is 2 or 3 bolts in this part which holds it inplace, quite tricky to get to.. if u lie on your back head near your pedals u can look up under dash to this part.. i had to replace mine once b4. it may need a tighten or u have a cracked part thus leaking coolant...
In the engine bay at the firewall there is 2 heater hoses 1 Return and 1 Feed side by side drivers side.. it is connected to one of these..
goodluck man let us know,,,
cheers will have a look at it that sounds like the prob cause thats where it was leaking from
