Results 1 to 4 of 4
Thread: Dissy bearing removal ?
    VL Executive
    Sep 2009
    Default Dissy bearing removal ?
    G'day
    I'm putting a new CAS in the VL ( she's been cutting out with no warning ) and am stuck on removing the bearing.I've done a search of the forum, can't find much. Do i need to remove the pins at the end of the shaft ? Any help much appreciated.
    98 VT Acclaim
    Aug 2008
    New Zealand
    VL Executive
    Sep 2009
    Quote Originally Posted by madrx3boy View Post
    Thanks for the reply mad. I checked out the link, unfortunately there isn't anything on removing the bearing once you have taken the dis out. I've got the new CAS all ready to go, there's no orange dust in the dis around the bearing, and there's no play in the shaft, but the CAS came in a kit with a new bearing. Just reading some of the posts on CAS's most guys reckon on replacing the bearing while you're at it. Any other ideas most appreciated.
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    the dizzy shaft goes through the bearing "downwards" - when i dismantled one (mind you I didn't care if it went back together or not) I just smashed the top of the shaft (where the button goes) downwards through the bearing.
  1. [ACT] WTB - RB30e dissy
    By my_vl_baby in forum Swap / Wanted to Buy / Trade
    Last Post: 16-06-2010, 09:08 PM
  2. Steering column top bearing removal
    By SMOKN_LJ in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-12-2006, 10:58 AM
