Results 1 to 4 of 4
Thread: Adusting Cam Shaft
    VT SS 5.7L Commodore.
    Feb 2004
    NSW, Australia
    Default Adusting Cam Shaft
    Hi,
    I have been told that it is possible to adjust the camshaft on the VL engines by advancing one tooth of the camshaft. Is this possible, and what modifications need to be done.
    I have a younger brother who wants to do this to his VL, but is having troubles starting it when he has tried it. Wonders if there is anything else that needs to be done.
    Thanks,
    Jim
    Feb 2004
    NSW, Australia
    executive vt 5.0lt
    Feb 2005
    west suburbs
    thelastjenko Guest
    one word DUMB???? problem starting. the reason being is your throwing the timing out way out thats why it will kickover funny you can only addust the cam on the rb25 heads with the twin cam and to do it on the 35 single cam heads you need to spend a bit of cash and but the addjustable cam teeth from a performance shop set ya back bout 450 i think
  1. What the balance shaft does
    By 14secvp in forum V6 Development And Modification
    Last Post: 30-11-2010, 10:53 PM
  2. Do i have a balance shaft?
    By Bent_6 in forum General
    Last Post: 08-03-2007, 10:03 PM
  3. CV shaft problem...
    By Hairy Eater in forum The Pub
    Last Post: 09-09-2006, 12:58 AM
  4. vt ss 5.7 tail shaft
    By evets in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2006, 12:02 PM
  5. Drive shaft
    By mr_vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-07-2005, 11:05 PM
