Results 1 to 9 of 9
Thread: Quick question about installing an exhaust system
    VLC86's Avatar
    VLC86 is offline ..stay N/A..
    VL Calais
    Dec 2009
    Default Quick question about installing an exhaust system
    Hey guys, just wondering how hard it would be to bolt on a 2.5" mendrel bent exhaust to my VL? It should go straight on as far as I know, but i dont want to pay the guy in the exhaust shop some ridiculous amount to install it if i can do it. How hard to you reckon it would be?
    opinions?
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    it's not really that hard, but if there is a problem like the exhaust doesn't fit properly then the guy at the exhaust shop would be able to heat and bend or adjust it so it does fit and doesn't knock or resinate/vibrate through the car.
    you get a warranty on workmanship so if it moves in a day/week or month you can go back and have it adjusted free.
    Nobody wants to play with me
    vl commodore and vz ss
    Jun 2010
    and remember to allow for broken studs its a common problem so be real gentle as well if you decide to do it yourself
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    As above on the studs.... Soak them with Penetrine.. like INOX/Wd40 a few days b4 hand and keep doing it so like 4 days b4 u do it start to hit em with it.
    Then the next day and so on.
    I used INOX on mine for 2 Rb30's with this process and did not snap any of the 24 Studs on both Engines...
    Carefull if the Exhaust is too hot when u spray it on... Wait till it cools, Common Sense Really
    VLC86's Avatar
    VL Calais
    Dec 2009
    sweet, ill keep that in mind. I was told that car will need to be really quite high off the ground, im guessing axle stands definatey wont be high enough. So ill need to find a hoist to do it all?
    Jun 2010
    ive done it off axle stands before and am about to do it again later this week i found the easiest way to get the old pipes out from around the axle is to just cut the shit out of it with the grinder also makes it easy to get rid of
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    hahah i did it with axle stands and managed to feed mine in this was a 2.5 system cat back me and another bloke. taken from one vl and put in mine b4 i did the turbo upgrade.
    Took it for a drive b4 the exhaust was in.. just Extractors loud and sounded mad as.. HAHA
    its manageable depends on the bends and so forth...
    VLC86's Avatar
    VL Calais
    Dec 2009
    well spoke to the guy at the shop im getting it from, $85 for fitment and will fix any problems with it for free if they occur. Seems pretty reasonable to be, so ill go with that I think
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    yeah i would 2..
  1. quick question about installing amp
    By liamvys in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-04-2010, 08:15 PM
  2. Installing exhaust system
    By wildeagle44 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-02-2010, 04:13 PM
  3. Quick Exhaust Question.
    By jokerflingo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-02-2010, 10:25 PM
  4. quick exhaust question - 5.7l
    By davway in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-03-2009, 09:43 PM
  5. Quick exhaust question...
    By spd_dmn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-09-2008, 05:30 PM
