Hey guys. Got a problem. Finally managed to get my stock exhaust off, i had to remove the cat converter too because one of the studs connecting the cat to the exhaust has lost all of the thread on the head and i cant get it off. i have used the blowtorch to get the other 3 studs off, and i have soaked it in WD40.. but i cant get it going.
Any ideas on how i can get it off?
replace the cuppling , i think u can get one from supercheap man , i am not sure if u got a welder but that might be the easer way man
angle grind a line through the middle of the head of the bolt (if its a nut angle grind off the excess thread then a line down the middle) then cold chisel off both sides.
or get a pipe wrench.
thanks for the help guys. After alot of blowtorching, WD40 and swearing i got it offWill need to get some new studs now to replace them now.
