Results 1 to 5 of 5
Thread: idling issues
    vl commodore and vz ss
    Jun 2010
    Default idling issues
    not sure how to describe it but when im sitting at the lights for a little bit the cars idle will drop and the whole car starts shaking like an engine mount is snapped its only just started hapening and doesnt happen all the time seems to happen more when its hot any ideas on where to start cause i havnt got a clue i have recently just replaced all the sensors so it cant be them
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    Jun 2010
    yeah its got rb30 in it cheers will pull it out and replace it see if it helps
    Nackerz's Avatar
    Jul 2009
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Mine just did this as well.. i went over all electrical plugs with some INOX. was also running rich as...Smelt really Smelly/Fuely with Black smoke
    Checked the AFM setting and was way out at 4.14v... Set it to 3.6V (Factory Lean)across pins 1 and 3 with the screw on the AFM itself with Ignition on and now is sweet as, idle is smoothed out and not doing it anymore at about 750 Rpm. Both LED's on the ECU flashing together same time at 2000 RPM
    Plugs and leads is a good start as well and as nackerz stated CAS could be starting to Fail
    Goodluck man
  1. Idling :(
    By ducatis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-02-2010, 07:51 PM
  2. 304 Idling issues. o2 sensor?
    By GTP 85 in forum V8 Development and Modification
    Last Post: 12-11-2009, 01:57 PM
  3. Help - Not Idling
    By Rachly in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-03-2007, 05:47 PM
  4. Low Idling
    By My Car Pwns in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-12-2005, 02:03 PM
  5. Inconsistant Idling
    By Corbin83 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-08-2005, 11:39 PM
